Picture update time...
I have started on the lighter of the grey accent panels, most will be on the upper hull half, so I work in a section then let it dry, then move on.
Front aspect, In this image you can see several finished panels, and several unfinished panels...
Upper hull Starboard aspect.
And upper hull port 3/4. on the left circled in red you can see a finished panel, vs on the right circled in blue the unfinished panels.
Under side of the mandibles are only large grey panels on the underside.
The lower hull half starboard side aspect.
And the underside of the deployed boarding ramp.
This is the part that I made my mistake on, the yellow was one panel too close to the end, so I painted over it, and repainted it in the correct location.
