Storm Talon
Discussion in 'WarHammer40k' started by silveroxide, Sep 30, 2012.
  1. arkon
    arkon Member
    how about a scaled down version of this for the quad guns
  2. terrinecold
    terrinecold Member
    I think the quad gun itself is defined in this one
    <edited, embedded the image instead of linking>
  3. jarobinson
    jarobinson Member
    Everytime I look at this thread I'm amazed by what you've done, and can't wait to see the finished product.
  4. silveroxide
    silveroxide Well-Known Member
    storm Walker
    Arkon, Terrinecold. Those quads are too large for the frame of the Walker. To make them more proportional, I will use the crew served Las cannon from the heavy weapons crew support team but with extended barrels.
    Jarobinson, Thanks for your comments but the thread will continue with two more conversions before I move on to something else.
  5. silveroxide
    storm Walker
    Almost getting to the end of the Walker but in the meantime, here are some more up. dates on the build. The weapons sponsons are done and I will post them a bit later. So far, it is looking good. Enjoy and see you all next posting.
      File size:
      32.5 KB
      28
      File size:
      32.7 KB
      25
      File size:
      28.1 KB
      22
      File size:
      25 KB
      23
      File size:
      26 KB
      22
      File size:
      24.9 KB
      20
  6. silveroxide
    storm Walker
    I am almost near the end of this build. There are just a few details to do but it is looking real good. Here is a teaser of the almost finished model and photo updates. The Las cannons will be enclosed in a protective casing, instead of exposed. The connector is removable and you can design other arms, claws, power fist or weapons. The stand is not what I was going to originally make but my ink supply is getting low at the moment. Enjoy and see you all next posting.:wave:
      File size:
      164.6 KB
      20
      File size:
      36.6 KB
      98
      File size:
      42.8 KB
      21
      File size:
      29.2 KB
      104
      File size:
      31.9 KB
      23
      File size:
      34.3 KB
      21
  7. terrinecold
    terrinecold Member
  8. silveroxide
    storm Walker
    Thanks for the accolade Terrinecold. The model is finished and here are some updated photos of the model. All that is left, is the editing and posting of the last photos of the Manned walker build. Next on the assembly line will be that Helicopter support attack helicopter. To keep it in perspective, it will not be as heavily armed as the others but it will have a good complement of weapons. So enjoy until the next build thread. The last phtos will be spread out since I can only upload six photos at a time. :wave::wave::wave:
      File size:
      23.6 KB
      21
      File size:
      19.3 KB
      90
      File size:
      19.6 KB
      88
      File size:
      24.9 KB
      21
      File size:
      22 KB
      21
      File size:
      21 KB
      90
  9. silveroxide
    storm Walker
    More photos, enjoy and one more posting to the finish line.
      File size:
      43.2 KB
      21
      File size:
      41.2 KB
      18
      File size:
      28.5 KB
      23
      File size:
      32.2 KB
      24
  10. silveroxide
    Re: Storm Manned Walker
    And finally, the last batch of photos of the Walker.
      File size:
      28.5 KB
      23
      File size:
      24.6 KB
      87
      File size:
      31.7 KB
      25
      File size:
      19.8 KB
      86
  11. arkon
    arkon Member
    WOW!!!!! do the side guns swivel?
  12. silveroxide
    The set up is for the middle section to rotate up and the sponson wil rotate up and down, so as to clear the upper portion of the legs. I glued the sponsons to the middle section but the whole weapons system can be removed and other options can be used into the center hole of the fuselage.
  13. Zathros
    Zathros Guest
    Man, that is awesome!! I think the legs are incredible., actually, it all is! :)
  14. lehcyfer
    lehcyfer Member
    I'm mindblown by your speed and detalization, especially that you're designing on the fly :cool:
  15. Rhaven Blaack
    Rhaven Blaack ADMINISTRATOR Administrator Moderator
    As always, you have done a TOP NOTCH job on this model.
    The engineering and attention to detail is absolutely FIRST RATE!!!
    I like the fact that you have made the weapons sponsons interchangeable.
    KUDOS to you on another fine job well done.
  16. ninja_doc
    ninja_doc Member
    Another work of art.
  17. jarobinson
    jarobinson Member
    Excellent work! It looks awesome!
  18. silveroxide
    Thanks to all of you for your words of encouragements. I am in the process of the next Talon conversion and I am stuck at the cockpit stage. The details are no problem but I have to build two pilots for it. The figure is coming along very nicely so far but I will not post until I finish one of the pilots and then I will post as to how I made it out of carved paper. So wait patiently and i will be back soon with the next project.:wave::wave::wave:
  19. jarobinson
    jarobinson Member
    Carved paper? I'm on the edge of my seat to see what you come up with next, I'm sure it will be amazing.
  20. fett92
    fett92 New Member
    Silveroxide, all i can say is wow, you are an awesome model builder, I have enjoyed reading several of your posts and am amazed at your skill in being able to scratch build stuff on the fly like that just amazing, thumbs way up!
