1:16 Space Shuttle flight deck
9,571
I think it is the way to go. They wore their space suits all the time after the disasters. Their suits provided the padding they needed, and in space, you butt doesn't hurt from sitting down on a spartan chair. I am sure that any gaseous anomalies would escape the suit, and it would be hard to say which astronaut was the culprit, but the carbon scrubbers would wipe the air clean. :)
Reactions: Tonino
9,571
There could have been stored an airbag there in case of an accident, as I remember there being a white cloth like box under there, but I cannot find the pic. It just may have been storage, as they used every nook and cranny. :)
Tonino
791
1,775
83
61
Republic of San Marino
www.facebook.com
Someone told me pic upload works again...
YESSS!!! IT'S TRUE!!! :D
Well here are other pre-builds to test fitting of new added parts.
First challenge: the joystick. It has a very complex shape. Very hard to recreate in 3D in this scale. I tried the "sandwich" method and realized a number of slices, imagining to cut a real joystick with a knife.
I left some slices back because the thickness would be excessive, but, even after some sanding at the edges, the result doesn't satisfy me a lot. This detail is put in "waiting mode"...
Here are some tries with ceiling details:
Here is central lamp and aft wall structure...
And here is side lamp with one of the mysterious pouches. After some searching I found some infos about them: they contained cable devices (one for every crew member, hence the numbering) used in case of emergency exit throug the upper windows.
And here is my very first attempt with pilot's chair.
It's just a draft to check dimensions and proportions. I already found a mistake: the seat should not be parallel to floor as I made it, but slightly inclined backwards, in the photos it appears to be aligned with central console (that is inclined) so I must correct the shape of the base.
Unfortunately I already have drawn the final seat pieces and now I have to modify them. Not a great problem: it's the nice part of vector graphics: you have just to shift some nodes and the drawing follows them as it was made of rubber bands...
Going to make a new test build for the chair. It's a very important piece of my cabin and I want it to be really nice! I'll be back soon
Bye
9,973
The joystick looks very good. I like the design of it. Although, I can see why you did not put in all of the layers. I can also see this used as a side joystick in a fighter plane (like a Viper or Advanced Thunder Fighter) :tank:
Everything else looks FANTASTIC!
KEEP UP THE GREAT WORK!!!
Reactions: Tonino
9,571
I could see those seats being "borrowed" for other projects!! :)
Reactions: Tonino
9,571
View attachment 156625 View attachment 156626 View attachment 156627
View attachment 156630 View attachment 156631
Bye
I bet they stored their extra "Pamper's" diapers in there. It would be embarrassing having to change a fellow astronaut. You have to throw down a tarp in case they peed their spacesuits. (Only parents get these jokes, and maybe Revelle-Fan! ). :)
Reactions: Rhaven Blaack
9,571
I think the "Bar" is now in orbit, and not is it only high, being in orbit, it's longer!! (check your physics) :)
Reactions: Tonino
Tonino
791
1,775
83
61
www.facebook.com
Slowly, step by step, I'm almost arrived to the end of this huge design work.
Now finishing all little bits still on the "to do" list.
Here are:
the HUDs
The bar hanging from the ceiling in front of commander and pilot's seat
The central element placed between front windows
And those two devices attached to lower rear side of front seats (btw: what are those things? Anyone knows what's their function?)
Next - and last - element: the joystick command boxes.
And then... ... ... ... ... the REAL build will start!!!! :D
