You guys are very kind, and your words actually do provide some great support, and I really appreciate that! I truly feel that this is a great model to build, and I would recommend it. I would hope too that this build information would help you, and you could add your own ideas to make a better example in the future.
Here are some more details of the gangways. They are kind of small so just keep that in mind. It reminds of if you were building doll-house furniture.
I lay the matching pairs of the gangway stairs side by side to allow for more accurate alignment. Otherwise, the stairs will look all crooked and all
These are the steps pre-assembled. Luckily, there's only one step on these! Thank God!
You can see from this picture where they go which is to the right and left sides of the fence. Just a nice little step to make things easier for the dudes to move around the ship.
There's not much detail shown on the plan, so these pictures will help!
Okay, moving on to these! Honestly, I don't know the proper name for these? It's not mentioned on the plans either? I just know there must be a special name? They are deck tie-down for various rigging lines that go up to the sails, and masts.
This is the plan detail for this one, but there are multiple assemblies on other parts of the ship that are similar.
I used a hair drill to go through the paper veneers, and to clean the hole through ready for the rigging lines in the future.
I can see that these are going to be VERY difficult to access without knocking parts around! But, we shall see I guess?
More than half built. They extend downwards far enough to contact the lower deck. Make sure to glue these securely, and to keep the holes fully open for the thread.
Oh, goodness me! LOL. Lots, and lots of railings to build! Each one has a hole for the thread to go through too! Each railing consists of 4 separate parts so, yes, this is another intricate section to build.
Just use a finger hold on the drill to avoid any accidental damage to the railings as they are built. There are NO spares either, so make sure to avoid cobbling one up!
These are the first railings that go around the gangway to the lower deck. I used a straight pin to make tiny holes for the glue to get a better hold for each post.
The Ship's Capstan Construction
Sailors would coordinate the rhythm of their movements by singing a particular type of sea shanty as they walked around the capstan. The tensioned portion of the rope would hoist a foresail and could also be used to lift a heavy spar into position on the mast or to transfer cargo to or from a dock or lighter.
I really enjoyed building this, although there were a few issues I found that required some re-work. These are all of the parts to make the Capstan.
I will show the steps required to build the Capstan.
These plates are layered on top of one-another to provide stepping.
