You had made the comment quite a while ago, about how the Viper MK-VII was considerably wider than that of the MK-II. So, why not leave it "as-is". That way, it can accommodate the Viper MK-VII.DANG! I goofed up big time. I was wondering why the window position did not match. Another look at the original blueprints revealed: I made the launch tube stall too wide! The original is 16', somehow I made them 5' wider... So back to the drawing bord to shorten all areas. That means the floor plan must be revised completely, too.
:robot3::robot3::robot3:
That works for me!!! thumbsupthumbsupYes, you are correct. I checked the dimensions again and found out that something else was in the way:
The inner wall design is too close together. The wing tips of the Mk VII don't get through.
To solve this issue I decided to alter the walls and remove the piece:
As a side effect the Mk. III will now fit inside, too:
It is a tight fit but it will do.
