I have gotten the windows painted brown. I still need to paint some stripwood brown, and add door trim to define the vestibule door locations. the brown window trim was not original to my scheme, but when Dr tom located the built Florence and Cripple Creek combine at a train show, and pointed it out to me, it was painted brown, and lettered for the Bonanza and Rawhide railroad.
It had full interior, very well done, and window glazing. the window glazing would have made repainting it to the State line railroad's green very tricky, and with the full interior, removing the glazing for repainting would have been too much work. I simplified the process by painting the window sills brown on my existing coach, and painting everything but the windowsills on the combine.
I spray painted the roof tan, both for the interior color, and for some priming. with these Labelle kits, the trickiest thing is sanding the milled roofing to the proper curve at the ends. the instructions have good templates, I usually end up doing it mainly by eye.
On the roof I still need to fashion some curved boards to carry the overhang on the celestory through the end curves. then there are some vertical elements to add along the celestory windows, and I have to figure out where the roof vents for the kerosene lamps need to go (the drawings in the kit don't show, and the interior set up as a parlor car will make it different from the coaches).
I will also need to paint and attach the platform , and the other bolster (the bolsters are integral to the platform castings so the one for the vestibule side I cut down to provide the bolster, and the coupler pad. the holes in the bolsters for the truck mouting screws, and for the coupler pads have been drilled and tapped, and holes have been drilled for the truss rods; so with the under carriage just needs to have parts painted and installed.
of that project assembling the couplers will be the toughest job. It is hard to assemble HOn3 couplers with the jig, and nearly impossible without it, I have already shot 2/3rds of the parts for one coupler halfway across the room. That is reminiscent of what, my old cohort Jeff, the transmission mechanic called a Jesus Clip.
folks would ask "Why is it called that?", and Jeff would say" When you take it off, He is the only one who knows where it lands."
Unfourtunately my green acrylic paint is at the club, so I can't touch up the new car, and deempasize the weathering on the other two till after monday night.
