In the meantime, this is the fourth time I rebuild the panel from the beginning.
II was not satisfied with the fastening of the dividers, as the wire began to fall out and does not stay in place. I re-printed the sheet with the panel, started to make, but immediately glued the transparent part, and the installation of the wire in a new way became not convenient.
I printed again, prepared everything for dividers installation, but when I started to remove the tape from the panel, it came off along with the toner, apparently there was some kind of printing problem.
The third time I scratched the panel, dropping its floor and ran over it with the wheels of the chair.
This is a new, more reliable way of installing dividers. I decided to weave them into paper. I used a 1mm steel rail as a support for leveling the height. This was my second reason why I decided to do everything from the beginning. When I manually setting each piece of wire, I cannot control its height, and it did not looks good.
