Mowe
goodduck
700
664
93
Rough in the rifle and cane for now, going to save that till the very last items to detail. I decided to make it in 1/6 scale almost 3ft wingspan(me like big model, <3, much, <3). I'm trying a new thing on the wing frame, shooting for bullet proof design... ok, maybe not bullet prove, just Allen prove will do.
goodduck
700
664
93
...... maybe I should make the wing fold..... pay no mind, just thinking out loud again....
Beautiful craftsmanship! if you are careful with the C.G., with some long trailing satin strips, I bet you could make a kit out of this, (second time this week I saw a model that could be made fly). The weight would of course have to be kept to a minimum, but with a 3 foot wingspan, you could get a lot of lift. If you could make a Styrofoam version of this, you would have a great toy on your hands!! :)
9,934
The amount of work and detail that you are putting into this model is absolutely PHEMAMINAL.
I like the frame work that you are putting into this model. It looks like it will be very sturdy.
You truly are a MASTER DESIGNER.
goodduck
700
664
93
I thought about vacuform, pre-cut vacuform kit would be nice. maybe I'll look into it some more when this done.
N
niebla de fuego
At 1/6 scale it will be the same size as the Folletto. It will be very interesting to seem them side by side.
Moewe will be big, but it surely looks nice. I've always loved that glider.
I was wondering about the inner structure of the wings, and I am happy to see that you are being very careful with it. With all those spars it looks like the wings will never sag.
Will it have movable ailerons?
Regards,
goodduck
700
664
93
The main frame section is going to be made out of corrugated sheet. Very careful folding required on that, I guess. I experimented on that with the Savoia.S21 early engine, it works really well, wondering how well it work out on a large scale.
A Nickel wire with a Rheostat shaped as an airfoil cutting aerospace quality foam would give you a wing with the strength of a surfboard! :)
N
niebla de fuego
Allen, after seeing this inner structure of the glider, and the way you design your submarines, I notice that you are making a real difference in the way paper models are designed.
While most commercial models of ships and planes used only a minimal amount of spars, ribs and bulkheads, you include a larger amount of these in your structures.
I like it, because I believe it is an intelligent approach to the structure. It parallels what was called "multi-cell" structure used in the DC-3 wings and other later airplanes. Is not exactly the the same technique, but your multi-spars and firmly placed bulkheads serve the same purpose: they spread the weight and the stress through several smaller structures all along the skeleton. That gives the final model an incredible strenght and resistance. And I know that! Destroying the first Savoia was not an easy task, it took a lot of time and effort. Other commercial models would not have survived at all.
Your kits will make models that will last longer than other commercial paper models. And not also that, your attention to detail produces really fine-looking products. I'm sure of that.
Also, seeing the screenshots of your design process is a most enjoyable experience. :D
Regards,
goodduck
700
664
93
Thank you very much for the kind words, and thanks everyone too. I like my paper model to be play toys, something that I can kick around and not just a shelf fixture look but don't touch. So structure integrity is very impotent to me. I know that in my designs, most of the time and materials are spent on complicated, overkill internal structure, I sure that will turn off a lot of models critics. But, I always want to try something different, experiment. I'm still a papercraft baby learn to walk, long way to go before I can run.
I broken down the parts some more, added card thickest and lap joint(that part is not fun at all). I also added a traditional center spar and cross ribs just in case the corrugated spar don't fly. ..... I addressed the fuselage frame again..... what else did I miss....? Okay, next time I'll address the aileron parts.
How the heck do you come up with these frame ideas!?!?!? You a genius Allen! :)
N
niebla de fuego
I like your concept: making paper models to be play toys. It sure is a big difference from just static models.
So, like the DC-3 and the B-17, your models can sustain a huge amount of handling, rough winds, flak, enemy bullets.... and still look good :)
I believe what you are doing is "paper engineering" more than just "paper model design". :D
Regards,
Ruben.
I agree Ruben. My 12 year old plays with all my models. It gives me great pleasure. It also makes for a better static model, as it will keep it's shape longer. :)
goodduck
700
664
93
I went back to rework the frame and bulkheads to accommodated the legs and handrails, also size down the rifle storage tubes too.....
goodduck
700
664
93
....both the handrails and legs are going to have to have a brass wire sandwiched between two card stock to hold up all that weight. ..... think I got everything but the skin nailed down..... yea, I think so. Next, I'll skin it.
You might be able to get Brass tubing at your local hobby shop that will slide inside each other. his will give you the ability to remove and repair the railing if necessary. Some of this tubing has flux built into it so it solders together really well. by flattening one end it would give a strong anchor into the frame. Just an observation. Looks excellent! :)
goodduck
700
664
93
Did some more work on the intake and exhaust. I forgot the vents under the fuselage so I addressed that now.
goodduck
700
664
93
..... and couple more pic for your enjoyment.
