Battlestar Galactica Power Sled MK-II (& MED-SLED) in 1:18 scale
9,952
Wow, what a neat model. Somewhere in my hoard collection there are a couple of these kits.
They are quite configurable and work well. I had started building a steam powered Holt tractor. Hmmmm… wonder where those parts are? I should build this model.
Thank you sir!!!
That is a really cool track system.
Reactions: mijob
9,952
@Revell-Fan and I decided to take this project to the next level by creating a stretcher (litter) to be stowed in the back end of the Med-Sled.
Starting with the outer skin of the stretcher.
The outer skin is assembled.
Here is the middle layer.
Inserting the middle layer (*NOTE* I alternated the directions of the layers to add strength to the joints.).
The middle layer is fully inserted in place.
Here is the inside layer.
Inserting the inside layer (*NOTE* I alternated the directions of the layers to add strength to the joints.).
The inside layer is fully inserted in place.
9,952
Moving on tot he outside greebling.
This is the support for the underside of the stretcher. I laminated it to 1mm thick.
The support piece is attached in place.
Here are the parts for the handrailing.
The handrailing is attached in place.
9,952
Now for the inside of the stretcher.
Here is the pad for the inside of the stretcher.
The pad is attached in place.
Here are the security straps.
Starting with the parts of the "male" strap.
The "male" strap is assembled.
Here are the parts for the "female" strap.
The "female" strap is assembled.
Here are both straps of a single set.
The first set are attached in place.
All four sets of straps are attached in place.
Two full stretchers are assembled.
9,952
The stretcher are now in the back of the Med-Sled.
You can have them laying flat.
Or you can have them stacked and laying on their side (and strapped to the roll-bar).
Please stay tuned in to your local Colonial Broadcast Network for further updates and they happen.
