(MK-I) Colonial Viper ("HELLO KITTY" livery)
11,263
Whilst I was working on the (TOS) Colonial Viper (MK-I), my fiancé and I were talking about the Viper, and the subject of "HELLO KITTY" products (as well as a few paper/cardstock models of unusual SCI-FI ships and vehicles that were made in "HELLO KITTY" livery) wormed its way into the conversation. She asked if it were possible to make a Viper in "HELLO KITTY" livery. So, after a long conversation with @Revell-Fan (requesting him to repaint the Viper in "HELLO KITTY" livery). He agreed to make the template (as well redesign the stand from the BSG Raptor for the Viper).
(*NOTE* Since I have already conducted two detailed builds of this model already, I am not going to be as detailed with this thread. However, I will be putting as much detail and greebling into this model as possible. Yes, I will feature the detail and greebling in this thread).
I started with the stand. Here is the template.
The stand went together easily. As you can see, there is a guide that will hold the Viper in place.
I then moved on to the cockpit interior. Here are the parts for the cockpit interior.
Starting with the cockpit tub. I detailed the control panels by raising the panels and recessing some of the screens.
I started assembling the cockpit tub.
I attached the joystick mount.
The Joystick is attached.
I closed up the tub and attached the seat.
Please stay tuned in to your local Colonial Broadcast Network for further updates as they happen.
I guess that it is time for an update. This time, it is the fuselage.
Starting with the parts for the inside of the nose piece. As you can see, I recessed the black circle.
Here is the fuselage body. I raised some of the printed texture that are inside the inserts (even though they will be hiding behind the laser canons).
Top view of the fuselage.
Bottom view of the fuselage.
Here is the connector piece that goes between the fuselage and the engine block.
The cockpit tub is attached to the connector piece.
The connector piece and fuselage are attached.
The inside of the nose piece is attached in place.
