Rogue one Tie Striker design thread
mijob
Tie designer
3,207
5,422
95
Netherlands
As I mentioned before I was not happy with thes size of the hatches. I cut the hatch from the alpha build to the size that I liked.
Fuselage with old hatch.
Fuselage with new hatch.
Old vs new
Also I have to fix the fuselage I used to much thumb pressure to fit the front dome on to the fuselage. I will re -rint the upperpart of the fuselage upperpart of the fuselage. Fingers crossed that I can fix it.
mijob
Tie designer
3,207
5,422
95
Netherlands
Pff last few days its was verry hot to work much on the striker model.
Today I finished some new parts. Smaller hatches and solved the problem with the thumb gap.
Below you will find the new template next up some cutting and glueing.
Keep in mind when working with paper that you can cut yourself.
