Tie Phantom Design Thread
mijob
Tie designer
3,187
5,396
95
Netherlands
Thanks Rhaven, yust some minor corrections these I will correct at a later time. I will make a new template wuth the corrected parts and mount these. parts on the alpha model. Next time I start with the wings.
Reactions: Rhaven Blaack
mijob
Tie designer
3,187
5,396
95
Netherlands
Thanks micah.
Nect you will see the cockpit.
This is the template.
And the parts cut out.
I tried to form the cockpit in the correct shape but this didn't work. I will make a couple of formers to get the right shape. This will make it easier to fit the front and rear end on the cockpit. Next I will work on the detail parts.
mijob
Tie designer
3,187
5,396
95
Netherlands
And some results of this weekend.
This component will be fitted next to the wing.
I dont like the shape of it. I will make a new box without a bottom. As you can see I cant fitted the recested part correctly. So I have to figure out a new way of mounting it. Maybe I gone place it on top with a surrounding.
Next installing the ionengine I.have used the ion engune.from uhu.. As you can see its to big for this model. I have to shrink it a bit that means a new drawing that I have to make.
Below some parts for the clocking device.
It doesn't fit that good I have to correct these mistakes.
I have made a list with all the things that I have to change. For the next couple of days I will work on this list.
