New Tie advanced X1 papercraft model
mijob
Tie designer
3,187
5,396
95
Netherlands
@bigptr yes I want to make a removeable hatch so you can see some inner parts below the pilot seating. Did you came accros somd better pictures?
bigpetr
Designer/Master Modeler
Jan 27, 2016
922
1,461
Czech Republic
Great. It will add something new and original. Eventhou I did not do this myself I like it a lot on models of others. On my X-wing build I did wings in permanent open atack position, because I knew I would never move with them anyway if I made them mooveable :), so it would be wasted effort and time to make them mooveable.
This removeable hatch can be perfect for maintenance diorama.
It seems, based on a picture resolution, I have the same picture.
Maybee this book can help, there are chapters on tie-advanced, but I do not own it.
micahrogers
3,773
4,639
Shannon GA
I had the X-Wing book like that, made to look like a Haynes service Manual. Lost it when I lost my house in Mississippi.
  • Wow
Reactions: mijob
9,549
Once built, you could round that Sphere with a Round edged tool, or a Ball Bearing on a shaft tool, forgot what it's called. ;)
mijob
Tie designer
3,187
5,396
95
Netherlands
Here are some drawings of the outer wing.
Again this will be a layerd wing.
First base panel
Second base panel
Then the "solar base panel". You have to cut these out and glue them on the "second base panel"
And the "solar panels" will be glued on the "solar base panel".
Next I will draw the wing details and greebling.
