- Apr 5, 2013
- 13,876
- 10,216
- 228
I'm a Master Plumber with 30 years experience, and while copper soldering, and brazing are second nature to me, electrical soldering drives me batty. With plumbing solder you want just enough flux to help the solder flow, and high heat, but I can never get the balance of solder, flux and heat right to do electrical connections. I burn the wire, or the solder falls off, or some such... I am trying to save to get a good Weller soldering station again, they actually do seem to help me solder better, but the one I had was lost in a move...Trick to soldering is lots of flux, sanding what you intend to solder, and lots of heat, and as little of solder as possible. The mechanical connection dictates the final solder. I try to wrap one aire around another, so I can slip shrink tubing on (which goes on first), and get a nice wire like solder, insulated. Of course, this will all be hidden, so who care!!![]()
I hope that your move goes smoothly and without any issues.A quick update, Voyager has been delayed since I'm moving at the end of this month. Hopefully I'll be able to restart mid-December![]()
I prefer solder wire that has flux inside it. I didn't know that when I started and everything became easy when I switched over. The alligator clamps on a posable stand was another great help. A long thin steel probe to nudge and hold pieces works good also.
