Sudsy's Benchtop - BMP inspired Chimera replacement
Sudsy
535
1,521
Rivet..... rivet.... rivet... or bolt heads. I think I might go sane doing this all the way. I might save this process for a more Orky vehicle until I figure out a uniform method of cutting them.
31JUL2019 EDIT: Next 20 pictures in the "BIMP 1" build:
20181125_195901.jpg20181125_174020.jpg20181125_174005.jpg20181125_173953.jpg20181125_173944.jpg20181125_173932.jpg20181114_201156.jpg20181114_201130.jpg20181114_201111.jpg20181110_162118.jpg20181110_162111.jpg20181110_162055.jpg20181110_161406.jpg20181110_161358.jpg20181110_161348.jpg20181027_143416.jpg20181027_143359.jpg20181027_143350.jpg20181027_113640.jpg
Sudsy
535
1,521
Comissar Gaius and Magos Lugh seem to not be too picky about the rivets thus far, I should not push my luck in the future however.
Being in the US with Letter size (ANSI size A) and not ISO size A4, I printed about 91% of full size when my PDF reader scaled to print margins. Part of this was to see how it compared to the GW miniatures. Looks good to me, the BMPs I crawled over were a tight fit for this Yankee, and I am 'average' (on the skinny spectrum when I was Active Duty military no less). So, it seems a good fit for Imperial Guard.
9,551
Nice and neat. Nothing like any of the too many work areas I have!! :)
Sudsy
535
1,521
Only neat because I have to clean up before dinner! Well, okay, I had to clean it up when my youngest got up from his nap... An old cookie sheet makes for a good rapid get away for the project. Now it is in a much messier (and not baby accessible) work area...
9,551
I remember those days :)
Gandolf50
1,332
1,585
96
New Mexico USA
For rivets or bolt heads, try and pick up a couple BOOK PUNCHES, the smallest sizes are in the 1mm range and can hammer out rivets far faster than cutting by hand. You can also try leather punches but you would have to sharpen yourself as they are far to dull to punch card stock, but a decent very small Swedish round file can take care of that!
here is an old thread link discussing them...
http://www.zealot.com/threads/compas-de-corte.179371/#post-1009222
Reactions: lyter1958 and Sudsy
Sudsy
535
1,521
This awesome! Thanks!
9,551
I saw a guy make a tip for an epoxy filled syringe, that was premixed, and he would push out the bolt heads to the desired thickness, then just cut them off. The epoxy didn't stick to the syringe, so hardening wasn't an issue. Lots of ways to make these details like this. I liked Gandolf's idea though, less messy! :)
Gandolf50
1,332
1,585
96
New Mexico USA
My pleasure! I got tons of advice just can't always remember it, after all these years!;)
Yep... I made a disk with a 1mm hex shaped hole in it for a clay tool that would squeeze out long 1mm hex string in sculpy, but baking them was a pain, and they were hard to stick down... Book punch is the way to go, wish I had the ability to fabricate a 1mm-and smaller book punch using brass tubing! I have thought about it, but getting the shape and the open tube to extract the punched out hexes is just not gonna happen anytime soon!;)
9,551
A Hex punch would yield many Hex shapes that could be laminated together. :)
Sudsy
535
1,521
Perhaps 3D printing will yield the desired result. Currently such tolerances are the realm of aerospace industrial 3d printers, perhaps in a couple years we might be able to print the desired tool on the desktop printer at home. Machine cycle time is slow for doing lots of parts, but just fine for casting masters or tooling. Already there is copper PLA blends with 80% copper that can be kiln treated to remove the PLA plastic and leave a nice coppper part, brass is not out of the question now.
Book punch is cheaper than the 3D printer and kiln, and it works today. I have already put one on my Christmas list!
9,551
Sintered metal parts are made with ridiculous tolerances, then baked to form gears for fine instruments. Aerospace 3D printers are almost unbelievable. The NASA 3D printer made parts for the new Saturn V engine, which can be shut off and throttled, using massive 3D printers. Incredible, this new printed engine is actually much stronger as there are no welds. An older, but still informative article resides here: https://3dprint.com/95914/nasa-3d-print-f1-rocket-engine/
Reactions: micahrogers
Sudsy
535
1,521
20181014_153527.jpg 20181014_153537.jpg What to do when power goes out... Work by a window!]
First snow of the, well, fall! It is the Midwestern US after all....
9,551
Looks great!! :)
Sudsy
535
1,521
So, I was reading around Zealot and ran across this great thread:
http://www.zealot.com/threads/raging-rivets.171785/
I figured I'd give Iehcyfer's method of using a pin and wood glue a shot. Instead, I ended up using a toothpick as my applicator. Worked out pretty well. Though I cannot seem to upload a picture of the progress. Is there an upper limit of pictures and file sizes per thread? I might have to delete or severely scale down the previous images...
Reactions: Rhaven Blaack
9,858
CG Admin is working on the picture uploading issue now. It should be working within a few days.
Reactions: Sudsy
Sudsy
535
1,521
Very much appreciated! I hope to have a few more to add to this thread when it gets fixed! Left side got the first set of rivets (or bolt heads), I hope to get the right side done and then continue assembly of the hull with the tracks.
