Where to buy track in bulk??
Discussion in 'HO Scale Model Trains' started by Rob24, Jan 8, 2008.
  1. Rob24
    Rob24 New Member
    Yeah, I am sure this has been asked 10,000 times. I even attemted a search.
    So where do you guys buy your HO track in bulk? I really don't like the idea of buying track $0.90 at a time.
  2. iis612
    iis612 Member
    Try Ebay, Walthers.com, search the Atlas website for there dealers.
    Flex track is sold in bulk.
  3. J. Steffen
    J. Steffen Member
    I bought flex track a couple bucks a piece. It went a long way and I still have half of it. I may use It later.
  4. Rob24
    Rob24 New Member
    Where did you buy it?
  5. J. Steffen
    J. Steffen Member
    My LHS. Comes in 36" lengths. I think most of the time it goes for a little over two dollars a length.
  6. doctorwayne
    doctorwayne Active Member
    Any decent hobbyshop should either have or be able to get you flextrack in bulk. When I got mine, the owner asked how many cases I wanted, then simply went to the stockroom to get it. I don't recall how much it cost, but it's quite a bit cheaper than buying it by the piece. One case did most of the layout that's finished to date.
    Wayne
  7. rogerw
    rogerw Active Member
  8. rogerw
  9. brakie
    brakie Active Member
  10. J. Steffen
    J. Steffen Member
    That's just way too much track. Unless a football field won't contain your layout.
  11. doctorwayne
    Larry's right: talk to your dealer and see if you can make a deal for the amount that you require.
    You'd be surprised how fast you can use up track. While my layout is an "around-the-room" type, the room isn't overly large and I've already used more than a case of 100 pieces, and there's still about a third more layout to construct. Yards, staging yards, and passing tracks will quickly eat into your supply.
    Wayne
  12. rogerw
    Agreed wayne. I seems to go fast.
  13. Rob24
    Rob24 New Member
    Thanks for the great replys guys! I thought there were cheaper alternatives then the LHS. I am all for supporting the local guys, but I also like to save money where I can.
  14. Wildcatfootball
    Wildcatfootball Member
    I can attest to this. Although my room is smaller then yours (or so I think, it's only 15x11) and after all is said and done, I'll need at least 70 pieces of just flex. I was very surprised at how much I'll need with how small my layout is.
  15. TruckLover
    it is amazing how much layouts eat up at flex track. I figure im going to go thru a whole 100 pack and then some for my trackplan just because i have so much track for my plan. I dont mind it tho, its more room for trains to roam the rails :mrgreen: :mrgreen:
