MasonJar said:
Jeff,
I am pretty sure that the staging tracks are flat (green, purple, orange tracks) and it is only the track from the helix (red) that decends over the yard to meet the rest at the top of the diagram...
Andrew
You're right Andrew, at least I think so. Where the quarter circle track leaves the helix is 3" above the bottom level. It can come down some, as long as there is enough clearance for the inside staging track. I haven't done the math yet, but I think it will work. Since this is a stageing yard as opposed to switching, keeping an entire train, including engine, on a sideing isn't out of the question.
TC, check the diagram below and maybe you can make some suggestions on increasing the distance between tracks.
Tracks A, E and F can be moved without too much trouble. B, C and D are where they are because of the switch block at the bottom, all #4s. According to the grid on RTS the tracks are 1.5 inches apart center to center. Just laying two pieces of flex track side by side at that distance, it looked like it would leave plenty of room, but like you say, things don't always work out like they should.
I welcome all suggestions and critiques. I wouldn't have gotten this far without them. :thumb: :thumb:
