Imperial Lambda-class T-4a shuttle TYDIRIUM
mijob
Tie designer
3,218
5,439
95
Netherlands
Yes first part of the top wing is assembled.
I first cut the base wing. I also copied the wing inner support lines.
Then I checked if the lines overlap eavh other.
Then I cut the top wing parts.
All parts assembled. And glued on the wing.
Next to assemble the other side and put some fibre in it.
12,413
Here comes the most interesting part: How close will this model come to the filming miniature? All mass-produced models from the well-known manufacturers have been provided with stretched reference images which resulted in wrong proportions. They got stills which were produced in 16:9 format but which were accidentally printed in 4:3 format. That led to a much higher profile, elongated wings and a stubby nose. The only models which have good proportions are the 1/350 F-Toys model (I have that one), the studio-scale garage kits and (surprise) the Kenner / Hasbro toy (which in effect is the closest when it comes to accuracy and it is about studio-scale as well). The paper model looks awesome in that respect but I have never seen any pictures of the profile when it is finished. With that being said, it would be great if you could post some beauty pics from the left or right side when the model is finished, Michael. :)
mijob
Tie designer
3,218
5,439
95
Netherlands
Started to assemble the left and right wing.
This is one of the side its straight forward to glue the parts.
When all wings are assembled its time to glue the inner supports. The wings are big so im not sure if the inner supports will keep the wings straight. Maybe I will use some big wooden bbq sticks.
mijob
Tie designer
3,218
5,439
95
Netherlands
Did some more work on the top wing. I glued the inner supports.
All parts cut and pre shaped.
When gluing the bottom part I used the top frame to check the fitting. Dont leave it otherwise it will be glued togheter with the wing.
All supports glued and some fibre assembled inside the wing. I drilled some holes with 0.5 and 1.1 mm.
Next I trimmed the fibre and fitted the LED.
And its time to test everything.
View attachment 20240225_150316.mp4
Im very happy with the result time to finish the top wing and assemble the left and right wing. We are close to finish this model.
mijob
Tie designer
3,218
5,439
95
Netherlands
Finished the side wings.
First the wing base and all the add ons.
Next copy the lines for the wing rotation thingy. Glue the supports in the centre of the lines.
Then cut and fold the other supports and assamble on a wing. I also added the fibre optics.
Then its time to glue the other wing make sure it is centred correctly otherwise you have a lot of work to make a good wing :headbange:
Indeed my last wing went completely wrong I have to see if I can use it. Also use a lot of hair clamps.
Only the last small parts to add and the wings are done.
Next to assamble are the wing canons.
12,413
Great job! I agree, those big pieces need extra care in order to avoid wrinkles and warping. Maybe you could laminate each wing with card and skip the internal formers and leave a channel for the wires. Of course that would add some weight to the wings but they would stay in shape easily. :)
Reactions: mijob
mijob
Tie designer
3,218
5,439
95
Netherlands
Thanks RF. Yeah that would work, only to late for me now. I will make some updates in my first posting so people know what (not) to do.
Afcourse I could build new wings maybe I will do that at a later moment and add some modifications to it.
12,413
OK, suggestion: Laminate each half of the wing to some card. This will strenghten it and help keeping its shape. Then add a third layer of card with a trench for wiring inbetween the halves.
mijob
Tie designer
3,218
5,439
95
Netherlands
I have started to make some changes in the template it is going to be an add on and will be available in our resource section.
You still need to download the original template.
