Danube Class Runabout (DS9)
9,600
Superb build of a model that is usually not built as well as this is. Very nice indeed! :)
Reactions: AdmiralGR
Famous Dave
110
Thank you for the build thread. I tried this a few years ago but it didn't go well. I ended up with another boulder. Anyway, this helps a Lot and I will try again following your lead.
Thanks again,
Dave
AdmiralGR
405
1,660
London
Thanks again,
Dave
I'm glad you like the thread! I look forward to seeing you build in the future and I'd be happy to let you know anything I've learned (not that I'm Any expert)
AdmiralGR
405
1,660
London
ACTUALLY, you appear an expert builder!
Thank you!
What was your solution to the nacelle issue?
Well, my priority was they lined up and looked correct, so i put a load of glue on the nacelle and pylon and held the nacelle in place so it glued in the correct place, but not flush to the pylon (see pic). it means there is a gap but wonky nacelles would have bugged me!! Had the model been plastic I would have put some kind of putty in the gap but don't have a simple "Card" solution to fill gaps
10,016
Back in 2013, I posted a thread on a very simple and cheap way to make "paper putty" to help fill gaps and cracks in models. Here is the link to that thread:
I hope that it will help you!
Reactions: AdmiralGR and mijob
AdmiralGR
405
1,660
London
Great idea
Thanks
Reactions: Rhaven Blaack
ennder
459
1,111
83
Hey RB you might want to make a downloadable PDF of this technique.
