1/12 Apollo Command Module
9,602
You've got some design work in front of you. :)
12,508
You are welcome! I'm glad to contribute something to this magnificent build. :)
Damn, that looks GOOOOOOOD!!!!! thumbsup
Reactions: zathros
9,602
Wow!! You make NASA proud!! You have really improved an already great model. Excellent craftsmanship. Revelle-Fan knows his stuff!! :)
P.S. I always tell people they use far to thick wire gauge for LED's, you are showing and using proper wire gauge. It makes for a clean model and allows a real wiring harness to be made, and is easier to work with. Kudos! :)
Reactions: micahrogers
12,508
(with the voice of a mad scientist who has just put together a creature made of spare parts: )
IT'S LIT UP!!!
:Drinks::Drinks::Drinks:
Absolutely fantastic!
Kolokolnikov
240
1,060
Almaty, Kazakhstan
I decided not to paint them, but to print them in the same color as Ken suggested. At first glance, the parts are not very difficult to assemble, they consist of only 5 parts. They are assembled very quickly without lighting. But! I had to tinker with the lighting, as they shone wherever possible! Just painting them black from the inside did not give a good result, as they glowed at the seams. I had to glue in additional partitions and paint them black, while I also had to cut out a part of the lower part to check before gluing the LEDs if there were any luminous slots left somewhere.
What the hell, it took me 4 hours to assemble these 2 small parts...
:headbange::headbange:
micahrogers
3,793
4,667
Shannon GA
View attachment 193206View attachment 193207View attachment 193208
Sometimes it's not the build that is time consuming, it's the modification needed to make it the way you want.
10,039
I'm not in a rush, I'm just surprised that I spent so much time on such simple detailsfor me.
Please do not flog yourself either. Sometimes it is necessary to spend extra time on a component to get it the way that you want it. I have done that many times myself. I have had to go through and completely rebuild a simple components several times, just because it did not turn out exactly the way that I wanted it to. It is the nature of this hobby.
Please remember that you are your own worse critic. We on the other-hand, think that you are doing an AMAZING JOB!
KEEP UP THE GREAT WORK!!!
Kolokolnikov
240
1,060
Almaty, Kazakhstan
Don't worry, too much praise isn't good either.
In general, for me, self-criticism is the best way to improve my work. I use this method in my main work as a commercial photographer, trying to analyze and improve my work every time, only I fully understand where I could have made a mistake, and next time I try to avoid it. Also, since I am very lazy, I constantly try to optimize the time spent in order to do a similar job in the same high quality but faster.
10,039
I know the feeling. I do the same thing with my work.
