Greeting ladies and gentlemen,
Once again, it is time for another update on this project. Here is the section that I am working on now.
In my original beta building, I laminated the tail with thin cereal cardboard for added strength and durability. I have decided to do the same thing again.
As you see, I have laminated the tail connector to cereal box cardboard to the desired thickness as well.
I layered the trim on to finish off the connector piece.
The connector piece is attached.
This is the cowling that goes under the engines (these are parts B4 & B5.
The cowling is attached.
Here is the tail section. I laminated a few of the parts to show detail and definition.
Starting with the underside, I raised the gray rectangle, and recessed the dark brown tail-end rectangles.
On the top, I recessed the dark brown tail-end rectangles, raised the two brown ovals in the middle of the tail and raised the spine.
I attached the tail section.
Please stay tuned to your local Earth Broadcasting Directorate channel for further updates as they are posted.
