REBUILD of ThunderChild's Warhawk
9,973
Greeting ladies and gentlemen,
Once again, it is time for another update on this project. Here is the section that I am working on now.
In my original beta building, I laminated the tail with thin cereal cardboard for added strength and durability. I have decided to do the same thing again.
As you see, I have laminated the tail connector to cereal box cardboard to the desired thickness as well.
I layered the trim on to finish off the connector piece.
The connector piece is attached.
This is the cowling that goes under the engines (these are parts B4 & B5.
The cowling is attached.
Here is the tail section. I laminated a few of the parts to show detail and definition.
Starting with the underside, I raised the gray rectangle, and recessed the dark brown tail-end rectangles.
On the top, I recessed the dark brown tail-end rectangles, raised the two brown ovals in the middle of the tail and raised the spine.
I attached the tail section.
Please stay tuned to your local Earth Broadcasting Directorate channel for further updates as they are posted.
9,973
Here is the next section of the build. These are the "long" engines that are under the tail.
These are the parts.
Starting from the rear tubing, working my way to the exhaust.
I laminated the arch "anchors" to the proper thickness of the skins.
The first long engine is finished.
Both long engines are finished.
The long engines are attached.
9,973
Now that I have recovered from my surgery, I can now once again return to this project!
Here is the stand.
Here is the front side of the stand. I raised the letters and the logo about 1 mm.
Here is the back side of the stand. I raised the photo of Hawk.
9,973
Continuing on with this build, I have moved on to the wings.
Here are the parts for the wing root and the wing tip.
The wing root is assembled.
As you can see, I have raised to circles and tabs on and to the side of the large circle.
The wing root is attached.
Here are the parts for the middle part of the wing.
The middle part of the wing is assembled.
As you can see, I have raised the leading edge panels, to add more detail.
The wing is fully assembled and attached.
Both wings are attached.
9,973
Well, OK...but we reserve the right to see Landing Gear..at Sometime !!...those Claws are so, COOL!
Yes, the claws are very cool. The bad thing is, they will not hold up the ship.
I attempted to make them three times and failed all three times. Some of the parts are very small and extremely difficult for me to make. I ended up destroying them in the process. If I decide to make it again, I will attempt the landing gear again. I may use other material of the very small fiddly parts that I had problems with.
