Buck Rogers Land Rover
12,375
AND FINISHED! :)
The bottom looks a bit plain and the wheels are a tad too deep inside the body. I have revised this on the final plans. The wheel will have an additional space of about 1 mm around them which looks better.
The original design however is so lowered that it is a miracle that the vehicle moves at all.
The wheelbox has got its former dark grey colour back and looks more like the Landram's (that seemed logical since it is very near to the ground and collects all kind of dirt during the drive). There will be more minor adaptations regarding the track detailing (hard to notice unless you put the Landram side-by-side).
Next: Assembly instructions! :)
9,953
OUT(FRAKKING)STANDING!!!
It looks FAN(FRAKKING)TASTIC!!!
I am looking forward to doing the BETA build!
I see a TON of detailing and greebling potential!!!
I am looking forward to seeing the how the interior will look and how it will fit inside!
Reactions: Revell-Fan
9,559
Dude you are incredible. I don't know how you can do so much so well. It's a pleasure to follow this thread, and a very cool tank!! :)
9,953
I am looking forward to seeing how the other two versions turn out.
I am also looking forward to seeing how the OPEN TROOP TRANSPORT will turn out as well.
(For those who do not know what the OPEN TROOP TRANSPORT, here are a couple of photos below).
9,953
I think that they should not be too hard to make. They also look like that they would make for a quick and fun build as well.
12,375
Last year I started working on these. I took a side view, traced the lines in SketchUp, pulled them out and in, changed the view - and noticed that everything was drawn on a single 2-D plane! So instead of creating a 3D model I ended up with a flat 2D line drawing..! :hammerhead:
Alright, texture work on the Draconian Rover is done. The turret is the final part to be unfolded.:)
Reactions: Rhaven Blaack
Sky Seeker
Well Established Member
Jun 1, 2015
1,178
1,083
95
View attachment 154908 View attachment 154909
These vehicles remind me of the vehicle in the original BSG series when they are on Peregrine with the androids. Looking forward to seeing the builds.
Sky Seeker
9,559
I may have to make a set of standardized tracks for these models, that will work and make them really pop! :)
9,953
Actual
Sky Seeker
Actually, these are the exact same vehicles. All they did was add decals to signify the "Earth Defence Directorate". There are many props that were used in BRTC25 that were originally used in BSG (to save on cost and make the limited budget stretch as far as they can.).
Reactions: Sky Seeker
12,375
A few props were designed and built for Buck in the first place and then repainted for BSG, too, because BSG got too expensive and Buck had a fresh budget. The EDD rifle and the Pumpkin shuttle (mockup & model) were two of them. The rifle and the matte painting of the space port from "Plot to kill a City" were later re-used in Star Trek: TNG.
