Greetings to all of you people...
Continuing with the purpose of building my models in order of appearance, here is my next ship.
As the "Tantive IV" makes an attempt to escape with the stolen plans of the Death Star, an Imperial Star Destroyer Imperator Class Ship is in full pursuit led by non other than Lord Darth Vader.
The model will have 57cm (22.5 inches) long and 37 cm (14.5 inches) wide when finished. The pieces are distributed in 28 pages. This will be (once completed) the largest model in my collection so far.
Given that has large flat surfaces the model will have to be reinforced mostly by cardboard. I will use pressed cardboard, 1mm and 1.5mm for the different parts that will make up the body of the ship and some details.
The ship's body is the basis of all the assembly for the rest of the parts and it will be composed of 4 large triangular cardboard pieces, on which will be attached the different parts that make it up. I don't know why the pepakura model divided the pieces into such irregular sections, but with a little care all fit together perfectly.
After that, stick on the bottom of each of the 4 pieces the details of the overhang on the edges and on the sides of the same edges so we do not see the cardboard. And also like the edge of each piece has a certain thickness, this one is increased with 1mm thick cardboard strips.
After finishing with the lower detail of each piece, we continued with the glued in pairs to thus obtain the upper and lower panels of the ship. A strip of paper on the junction of the two pieces would leave a "hinge" which would allow graduate the inclination of each panel to get the correct form of the ship. This angle would be dictated by the form obtained by the tail piece. This piece is reinforced with cardstock, to give more rigidity than just paper and once assembled will be ready to form the base of the ship.
As we begin the assembly of the base, I started with the lower panels of the ship, to these were added the side pieces that will give the separation of the upper parts from the lower ones, then I added the tail piece and then allowed to to dry thoroughly before proceeding. With the tail piece installed and the ship beginning to take shape, I placed some internal reinforcements to make sure that the angles of the lower panels don't suffer any variation by handling in the future. Once this is done you can proceed to place the "lid"; I mean the upper panels of the ship's body, to close it and obtain a solid basis for the assembly of other parts.
And ready .... you get a solid base, handleable, on which you will work the details. The ship is taking shape and is quite resistant to handling. Next I will work on the details of the ship and finally the upper superstructure and weaponry.
Until here for now... see you guys on the next progress post....:thumb:
Saludos.
Tiluchi
Saludos.
Tiluchi
