Great model sjsquirrel!
I like them tinies, so here's my design. Hope all likes!
Now that Super dooper cool:thumb:
With the PDO file and Pepakura Designer you can easily scale it up, rearrange the parts and re-print it. This isn't too much work, although some pieces will end up being split over multiple pages.
If there is interest in a bigger version all you had to do was ask. :mrgreen:
Give me a size and I will make it happen. Of course, that will take a little time out of my work on the SR2, but that's life.
@ Goncalo - it looks like someone created a model and has been building it, but nothing was released. There are references to my SR1 model, and a link to the 3D mesh I am using to create the SR2, but that's all so far. Too bad too. His model looked great. Might be worth monitoring that thread to see if anything further develops.
Sorry about the slow progress. Too many shiny things in the world, and I have been working a lot. Unfortunately paper modeling doesn't pay any bills. I've wrapped up the two things I was building though so I plan on focusing more attention on this project for the next week or two.
Stay tuned,
Steve
On display. Oops, I guess I should dust.:mrgreen:
Nice shot F131. Everything on that shelf is in my build queue. I just wish I had a shelf like that to put them on.sign1
As for the SR2, I've started unfolding the main hull and correcting issues as I go. Hopefully I'll have it ready for test building this week. I'm experiencing a period of project ADD lately having worked on the SR2, a colt 1911 model, a 1/200 version of my Airtractor, and another generic handgun. And that's just 3D and Pep work, not the stuff I'm actually building. Focus....must.....focus!
And by the way, I don't believe I've seen it mentioned in this forum, but one of our colleagues at papermodelers is designing a new, much more accurate model of the Normandy SR1 (saving me from having to go back and do that). It's shaping up to be a fantastic model of the SR1 to go with this model of the SR2.
Stay tuned.
Steve
Steve is this the website that your talking about on of the colleagues that is redesigning the normandy sr1, i been watching the progress on it the texture & structure looks more accurate.
http://www.papermodelers.com/forum/alternate-dimensions/14243-mass-effect-sr1-normandy.html.
Mark
And just so you don't have to take my word for it, here's proof of progress.
The internal formers are done and the unfold is in progress. The first two pages are unfolded and just need lines touched up. The last two pages (formers) are also done. That just leaves three pages of hull sections to refine the unfold - there are a number of issues probably not visible in this image - then touch up the lines. With luck I'll get it done tonight. Then I need to go over it with an eye for the flaps
Bye for now
Steve that look great on the unfold & the structure of the fuselage is going to be strong i notice on the first normandy sr1 each section where you join together it started to twist & the fuselage was out of wack but maybe that was just me when i build it.
by the way if you need me to volunteer to test build for you i would be happy to help in anyway i'm not worry about wasting ink i got 100 ink cartridges :mrgreen:.
Mark
Continuing from the previous post...
I wasn't happy with the way the two sections lined up, and the second section didn't turn out quite right. If you look closely at the last picture in the previous post you'll see that the texture on the upper part of the second section does not line up properly with the center of the end panel. I'm somewhat baffled by that, but it had to be fixed.
I went back to Pepakura and split the hull skin into two pieces (top and bottom) and rebuilt both sections. The first image below shows the ends laminated to heavier card, the bottom skin has been scored and folded and the bottom reinforced with heavy card. This adds strength, but more importantly helps it hold the shape.
The second picture shows the end pieces glued to the bottom skin. I ended up making a vertical former to put between the ends to hold them the proper distance apart. I'll add this to the final kit, adjusted to allow for the thickness of the ends - I'll have to assume 1mm card I guess. Gotta assume something. I think mine ended up about 1.5 mm overall. The recessed panels were then added as before and the sections glued together. The third picture shows the two attempts side by side.
On my first attempt the top texture didn't line up with the center-line properly, but a slight twist between the first two sections compensated for that. The bottom side doesn't look quite as nice though.
On the second attempt there's a small but annoying gap on one side between the sections. I'll definitely be adding lengthwise vertical formers for these first three sections. I didn't include them originally because they are so small, but the curvature of the hull (see final picture) makes them necessary.
So far so good. A few problems but nothing major. The textures are looking good, even after Pepakura downsized them. We'll see better when we get to the bigger pieces.
This is the only thing I'm building now so I'll post progress a little more regularly. Stay tuned.....
Steve
Happy (belated) Birthday, Mark! I just turned 23 myself a month ago. 8)
Hey Steve, that's a pretty good start. Are those increments on your cutting mat centimeters or inches?
Looking good. I like the "Wescott" steal rule too. Nothing like it for making clean lines, or clean cuts on a straight line. Looking forward to your progress.:thumb:
Hey Steve great progress on the front nose keep up the good work.
would balsa wood work in some section of the hull like the fuselarge ribs & support strips aswell or is it to weak for this work.
by the way i had a great time on my birthday i'm now 22 but time is going too quick & we got to enjoy life while you can life is to short.
Mark
