I'm still working of just keeping it upright and not crashing into the ceiling of tunnels and bridges!
Right!!! The engine was the engine.. and classified as such... The tenders were "add-ons"I suspect that one reason that tender wheels are not counted is that the tender was detachable from the locomotive. I don't know if it happened or not, but conceivably a locomotive might use a different type of tender so that if the locomotive used the tender wheels for classification and then changed tenders it's classification would change. In the case of the beast that Mountain Man linked to, since the last set of drivers is actually on the tender, the tender would not be detachable therefore the tender wheels should be counted. Can you imagine trying to get that thing around a curve?
...... since the last set of drivers is actually on the tender, the tender would not be detachable therefore the tender wheels should be counted. Can you imagine trying to get that thing around a curve?
A Mallet would be somethign like 2-6-6-4. A 4-6-2+2-6-4 is a Garratt.Additions are used for things like Mallet engines - 4-6-2+2-6-4, and other specifics may use letters, like adding "T" for tank engine.
Well, since the 2-4-6-8-10-12 isn't actually a real locomotive, it's much ado about nothing.
It would make an interesting model, though.
Brutus the barber has been quoted here but I don't see his original post. Am I missing something.
Les
Les
Interesting proposal... even if it's a photoshop job. Isn't it a 2-4-6-8+10 though? "+10" for the booster (i.e. powered wheels on the tender) and no "12" since unpowered axels on the tender don't count?
Andrew
Yes.
He, like me, was snipped for being snippy. :whip1:
Not quite. A vasectomy doesn't show so no one knows you've had one. This shows so the whole world knows...Huh, is that anything like a vasectomy?
Oh I Hope not.
Joe
Oh I Hope not.
Joe
No, but it can be emasculating.
Actually, the full form of the European system does that. http://en.wikipedia.org/wiki/UIC_classification uses an apostrophe after any set of wheels that pivots.Trains magazine tried to adopt a reformed Whyte system a while back that would give extra information. I think -(6)- indicated 6 drivers that swivelled.
