Ford F550 Super Duty Ambulance (Polk County)
Here are the greebling details for the top of the cab and box.
I started with the cooling fans and solar panels. As you can see there is an option for both solid blue solar panel or with a refletion of the sun.
I chose the solid blue panel for this build.
This is parts for the cap that goes on the box.
The cap is assembled.
The cap is attached in place
Here are the parts for the golight and antennas.
The golight is assembled and attached in place.
As you can see, it can rotate back and forth.
The front antenna is attached in place.
The two antennas are attached in place.
It is time for the running boards. Here are the parts for both the rear and side running boards.
The rear and side running boards are assembled.
The rear running boards are attached in place.
The side running boards are attached in place.
Here is a short video.
View attachment 20250320_203038.mp4
Once the rain stops and the pavement is dry, I will take "nature" photos.
The rear board looks good. The side boards must be fixed, they are in the wrong place.
