Tie Predator design
mijob
Tie designer
4,018
7,086
95
55
Netherlands
The template for the Marauder is almost done so I'm looking for a new design project for the weekends.
I will go for the Tie Predator below some pictures.
Schermafbeelding 2024-09-08 095515.jpgSchermafbeelding 2024-09-08 095730.jpg
And I also found a nice looking blue print that I can use.
It is a very simple looking model but there are several challenges that I would like to tackle>
The Sphere is not the problem but the moveable wing construction is a nice part to work on.
There are not that much details on it but in this case less is more.
View attachment 220134View attachment 220135
Are you planning to make both versions, or just one?
Reactions: mijob
It appears that you are off tp a great start!
Yes indeed its not that hard compared with the Marauder.
And I have a new update on the front side of the wing.
And here are the parts.
Next will be the rear side of the wing.
Im thinking to use grey board to make a thicker wing maybe 1 mm thickness is enough.
