Battlestar Galactica/Buck Rogers Hover Vehicle
10,010
I can safely say I have never seen this 'at-all!' - or recall seeing it on telly
As I had mentioned in my opening post, This vehicle was used in both Battlestar Galactica and Buck Roger in the 25th Century, and had several very different paint schemes. Here is a list of the episodes that it was in:
Battlestar Galactica: "Greetings from Earth"
Galactica 1980: "Space Croppers"
Buck Roger in the 25th Century: "Unchained Woman" (x3 different paint schems)
Buck Roger in the 25th Century: "ESCAPE FROM WEDDING BLISS"
Reactions: mijob
10,010
These are the parts for the "propulsion units"
The "thrusters" are assembled.
The "propulsion units" are attached in place.
Please stay tuned in to your local Colonial Broadcast Network as well as your local Earth Directorate broadcasting channels for more updates.
10,010
Finally the hand railing, handles, and spoiler.
The spoiler is assembled.
The spoiler is attached in place.
I attached the mounts for the side handles.
The handles are attached in place.
I attached the hand railing mounts.
The hand railing is attached in place.
Chuffy70
842
1,709
Norwich UK
Have not see either since they were first on tv, A friend recently gave me the box set of Battlestar, I'll have to watch and see it in action
10,010
Since @Revell-Fan has made a few significant changes to this model template as well as added a few new features, we thought it would be best to test out the changes. I am now test building the new template (in 1:32 scale, this time).
(*NOTE* Since I have already conducted a detailed build earlier in this thread, I will only focus on the parts and components that have changes. Otherwise, the build is the same as before.)
For this template, there are nine sheets of parts.
One of the main changes, is the new "unibody" shell. This eliminates the seam between the front and rear half of the vehicle.
Here are the side and front section, and head light assembly.
The light assembly is assembled.
The light assembly is attached in place.
Another significant change, was adding another compartment to the vehicle. Here are the two compartments.
The two compartments are attached in place.
The body pieces are ready to be connected.
The body pieces are attached in place.
10,010
Here are the internal formers.
The formers are assembled.
The formers fit snuggly, inside.
(*NOTE* Do not glue the formers into place.)
Here is the operator's cabin frame, control console, and steering wheel.
The operator's cabin frame and control console are attached in place.
The Operator's cabin interior is assembled.
Here are the interior side panels to the operator's cabin.
The left interior side panel is attached in place.
The right interior side panel is attached in place.
The interior operator's cabin is attached in place.
(*NOTE* I took the formers out to install the operator's cabin.)
I attached the the bottom plate.
10,010
Here are the parts for the "energy packs" and the intake system.
The "energy packs" are assembled.
The "energy packs" are attached in place.
The main components of the intake.
Assembling the intake.
The intake is assembled.
The intake is attached in place.
This is a "step" that will be attached to the back end of the intake system.
The step is attached in place.
Both sides are complete.
These are the parts for the "thrusters"
The "thrusters" are attached in place.
10,010
Earlier in the thread, I mentioned that @Revell-Fan and I decided to add a "hidden" compartment under the "spoiler" (which was featured in my last update). We also discussed the possibility of having different coloured "spoilers", and adding numbers to indicate that there are several "service" vehicles in the "Colonial Fleet". Yes, there will be a sheet of number panels for the spoiler so that builders may "customize" their own hover vehicles as well as making several for a diorama.
Here are the parts for the different "spoilers" and the insert.
I chose the all black "spoiler".
The "spoiler" and insert are assembled.
The "spoiler" is put in place.
(*NOTE* DO NOT GLUE the insert tot he inside of the compartment. You should be able to remove the "spoiler" to show the "hidden" compartment).
10,010
@Revell-Fan decided to make a very interesting and detailed underside for the Hover Vehicle, by designing the "hover" mechanisms.
The "hover" discs are assembled.
The "hover" discs are attached in place.
Here are the parts for the rest of the components.
The components area is assembled and attached in place.
The outside of the "skirt" is applied.
