Y-WING BUILD - Construction continues...
Chuffy70
With a love of Star Wars and the many star ships and vehicles within the universe, the Y-Wing or The Koensayr BTL Y-wing assault starfighter/bomber has to be my favourite.
Generally considered to be the workhorse to the the more glamorous X-Wing. A kind of real world comparison could be the Hurricane to Spitfire.
Anyway, I've had a go at the Y-wing before, but that was a disaster of a build - a small kit, blown to large print on horrible stock, which resulted in me dumping it, although it did go to a home for rescued and unloved spaceships.
This build was forwarded to me for my perusal and thought it would make for a good trial on newly acquired cardstock. The only thing I know of the kit builder on this one, is that his name is Stephen.
There's no instructions with this build, but as its a favourite of mine, identifying the pieces shouldn't prove too much bother.
Below is the truly awful attempt - built from a table top gaming pattern.
test parts for this build are just the cockpit section
Internal parts acquired for cockpit
All folded and formed - well as far as I could tell without instructions!
Rear of cockpit bits and bobs
Cockpit window frame located
...and finished internals and cockpit frame
The newly sourced cardstock made this build a delight to make, although a wee bit frustrating as to the location of parts.
I'm not sure if I'll build the rest, but if there's enough interest I may carry on.
MTFBWY
mijob
Tie designer
Wow you are of for a great start it looks verry crisp and clear. For sure I gone watch this trhead.
This looks really good! You are off to a great start!
I have the same template. However, mine included this assembly diagram. I hope that it will help you.
Chuffy70
Cheers for the template Chris, which is good for the first one I built, as pictured at the top - but the creator of this more detailed version has 5 CGI pictures with his files and that's it - did anyone else build this one or am I the guinea pig here?
I am glad to be of help.
Sadly, I think that you are the guinea pig on the second one. I am looking forward to seeing how this one turns out!
Yes, it seems that you are the first one aside from the original creator. This model is on my todo list since it is the most detailed Y-Wing papercraft available at the moment, so I may join the club one day. :)
Chuffy70
Cheers, best I continue the build then...although Dewey needs to be finished first...sadly nothing will be done this week as my partner has taken over the bench with her sewing machine!
will69
Are the templates Still available somewhere? I found the forum where it was built, but no templates.
/ Wilhelm
Chuffy70
Small amount of progress on the cockpit/nose section using up the rest of the good cardstock.
This included the top panel sections and the side skirt.
Well that's all for today on this one - will be picking up the rest of the fuselage soon, when the copy-shop has more decent cardstock.
Your cuts are very precise and clean. I really like how she's coming together! :)
THE DC
Highly Esteemed Member
This is really coming along!
I plan to watch this build.
And I agree with your assessment about the X-Wing and Y-Wing; I always preferred this ship!
This is coming together nicely!!!
This model has a great deal of greebling potential!
