Tie Phantom Design Thread
mijob
Tie designer
3,251
5,497
95
Netherlands
Hello All,
And this is my next project.
Designing of the Tie Phantom.
It's gone be a large model 20 cm long, 10 cm heigh and 14 cm width.
My firts inkscape steps.
I gone modifie this model with parts from other Tie's for example the rear section with the ion engine.
So stay tuned.
mijob
Tie designer
3,251
5,497
95
Netherlands
And here are some drawing's in progress.
Below the cockpit. As I said I will use some elements from the Tie fighter / interceptor.
Ion engine also with some elements fro the fighter/interceptor
And the last one is the wing. It's a big wing.
I think I got almost enough pieces to make a Alpha version.
So stay tuned.
12,462
WOW! That's something you can work with! Great idea to contact the designer. :)
Reactions: mijob
12,462
BTW, please don't be confused because of the "40mm". I chose a random even number so that is easier to calculate the rescaling factor. Resize the pattern to make it fit.;)
Reactions: mijob
micahrogers
3,787
4,654
Shannon GA
I'll admit, it's not one of my favorite TIE designs, but I'll be watching the process.
Reactions: mijob
micahrogers
3,787
4,654
Shannon GA
So far, your designs and builds have been a joy to watch. Good luck, and God speed.
  • Love
Reactions: mijob
10,005
Today I worked on the solar panels and their surroundings.
First I will make a alpha build with only the basic parts.
May be a few parts with some detail on it for the looks.
I hope you will enjoy this build if you have questions or suggestions please let me now.
Iam looking forward to seeing how this will turn out.
Reactions: mijob
mijob
Tie designer
3,251
5,497
95
Netherlands
Lets print and build the first rough outline of the Tie Phantom.
This is the main body some parts are familiar. And this is the wing with the hyper drive engine
Only thing todo is cut and glue. Then I can start fabrcating new parts and see how they fit on the model.
So stay tuned.....
