(TOS) Colonial Viper (MK-I)
This time, the engines are the topic of this (long awaited) update. I started with the top engine (as it had a couple of added features that the other two do not).
Here are the parts sheet for the top engine.
Starting with the intake. I louvered the "fans" and "domed" the center piece.
The outer skin of the intake is attached.
The intake is complete.
I started on the exhaust. The two parts of the outer skins are for recessing the rectangles.
I raised the ribbing.
All of the ribbing is attached.
The outer skin of the exhaust is complete.
These ae the parts for the inside of the exhausts. I laminated the physical texture parts to (about) 0.5 mm.
The exhaust is complete.
This is the assembled center (main body) of the engine.
This is the assembled cone that goes between the main body and the intake.
I raised the details and formed the straight pieces (that run the length of the piece) into "half-pipes".
The cone piece is complete.
The engine is completely assmebled.
All three engines are assembled.
Continuing on with the engine assembly (and other components on the engine mount).
I attached the engines.
These are the brackets that go around the engine exhaust (they are laminated to 0.5 mm).
The brackets are in place.
These are the spacers that go between the bottom engines and the bottom center plate.
The spacers are in place.
These pieces go one each engine (one per engine).
I laminated the hexagonal pieces and the rectangles (each) to 0.5 mm, then put the rectangles on the hexagonal pieces.
The hexagonal pieces are in place
These are the panels that go on the sides of the engine mount.
The panels are complete. I raised all of the details and greebled the panels as much as possible.
These are the "hoses" that go from the panels to the engines. The are laminated to 0.5 mm.
The panels and "hoses" are in place.
Please stay tuned to your local Colonial Broadcast Network for further updates as they come in.
It is time to attach the wings and tail so that this thing can actually fly!
Earlier in the thread, I had posted that I assembled the wings and tail. Here they are again.
The wings and tail are attached!
Reactions: Rhaven Blaack
