Star Wars T-70 - building thread - blue version with additional details
starbuck
898
1,825
93
Austria - Carinthia
Hi together,
the model is available in different color versions on the internet. I have built the model before and gave it away. This time I would like to build the model in more detail.
The biggest problem is that there is no cockpit. Since I have no skills to create a cockpit, I can only try to take an existing X-Wing cockpit and try to modify it to the correct size. Let's see if it will work.
starbuck
898
1,825
93
Austria - Carinthia
Oh forgot to mention - i reduced the glueing tabs on one as an be seen on the last 2 pictures, as I remembered that it was very tricky to hide the tabs on the upper side. Second thing was that the sticks are perfect to be inserted the existing wholes, but they are a little bit to strong for those parts which will be wrapped around. So I had to make the stick a litte bit narrower.
All parts finalized, but not glued! I will not glue before the final assambley to ensure that the cannons are finally properly aligned.
Next the body....
starbuck
898
1,825
93
Austria - Carinthia
Next step is adding the single panels on the hull and giving additional details.
starbuck
898
1,825
93
Austria - Carinthia
....regarding the droid plate: within this version the dark plate is delivered, but I prefer the brighter one which I took from the Ralph McQuarry version ;-)
starbuck
898
1,825
93
Austria - Carinthia
Yes I can wait and I will as I know it is worth waiting for. Whenever you find the time. There is a lot to do on the remaining parts and I have many projects on the table. thumbsup
12,361
So we are witnessing some interference from the dark side. Good, good! :hide:
Yes, it is not easy to resist.:fight: Probably this is why it already looks so good ..! ;)
BTW, where does that BB unit come from?
Reactions: Cybergrinder
9,549
@bigpetr this would be very nice of you. And with your help it will be perfect as all the details you made before.
The cockpit with windows is prepared
You have to fix the bottom top edge of the cockpit, the cuts are just too noticeable (wiggly line).. The top edge is so perfect. You'll hate yourself if you don't, the rest of the model is coming out so damned good!! :)
Reactions: starbuck
bigpetr
Designer/Master Modeler
Jan 27, 2016
922
1,461
Czech Republic
Starbuck, here you have it. Cockpit from imcold X-wing adapted to this model. Please dryfit everything since this is not tested and there could be errors. You are the beta tester here :)
  • imcold cockpit adjusted for T-70.pdf
