Yamaha MT-01 Ultra Realistic build
Very impressive. You know if you replaced that spring with a real one and made the swing arm pivot, You would have a working rear suspension. Looks absolutely great!!
retunga
Designer
Jan 15, 2012
174
106
Planet Earth
www.watch_this_space.com
I see what you mean with the wire in the handle bars, For the V-Max I assembled the handle bars complete first then I put the gips and mirrors on afterwards, one thing that I did do is to use a bit more glue on the joins as to build up the strength, the model needed to have more holding joins on the pipes to get the holding strength up, but your model is looking good, well done.
I am now just busy doing the exhaurst sysem staddle then I am done, I have also completed the wheels early on.
barring any major delays I am aiming to be finishing by the middle of November with the model.
R
retunga
Designer
Jan 15, 2012
174
106
Planet Earth
One thing Zathros with making the spring work on the MT01 and The V-Max is possible, but there is some mods that need to be done in that of adding extra strength to the hinge of the shock and arm, when the model was designed Mr Jap did not add that extra bit space to do that, I have throught about it for the V-max and I gave that idea a skip because the space needed to get it to work, the one thing that would also be good is to get the kick stand to also move as well but again space is a bit tight and strength again.
R
NeoThyrrus
Ooooookkkaaaayyyy ! Here's the last step before Final Assembly !!
I haven't posted lately, you know how it is, busy with work and everything....
But here I am back in business if i can say and this post will regroup the last part of the pieces assembly and the Final assembly ^^ (be prepared there's a HUGE amount of pics, something like more than 200 ^^)
So here comes the the assembly of the last parts !!!
So in order of appearence :
- Fuel Tank
- Exhaust Pipes
- Seat
- Left and Right Footrest
- Tail Lights
Let's start with the fuel Tank....
First like always a pic of all the pieces :
Building step by step...
Let's switch now to the Exhaust Pipes
I've only covered the assembly of one of the pipe since both are the same...
Let's continue with an onother set of Pipes, with the group pic of the pieces to start...
Let's now build the Seat...
NeoThyrrus
Now let's follow with the Footrest
Here's the Right :
And the Left :
And finally the last part of this bike : Tail lights....
Ok Let's not Start the Final Assembly of this looooong project.....
Let's start with the traditional pic of all the pieces together before assembly
Ok let's start...with the Engine and the Lower Frame part :
We now complete this with the Upper Frame part :
We now put in the Air In-take :
Let's now move to the Exhaust Pipes :
Adding the Tail Lights :
Let's switch now to the Seat / Rear Pipes / Fuel Tank group :
Fixing the Pipes to the Seat.....
Which we add to the Frame :
NeoThyrrus
And finally the Fuel Tank is added also.....
Let's now move to the Rear Arm and Rear Tire :
Which are now added to the main part....
Let's now add the Side Covers :
Now adding the Footrests......
And Finally (at last) the the assembly of the Sterring and the Front Tire and the Front Light.....
And here is the final pic of the assembly :
You can see that I have waited for the last time to add the Side Stand because i wasn't sure to how to place it, and I've decided to place it on a open position. for that i had to reinforce it with toothpics ^^ so it can serve its original purpose : make the bike stand ^^
Voilà ! it was a long build but here it's done....c'était long mais j'en suis venu à bout ^^
But since you like it i 'm adding some last pics of the model in many angles :
I have now started and finished another model : in build War Machine and completed : Goddess Athena from Anime Saint Seya.... post will come for those ^^
Those may have been the biggest pictures ever posted here! Normally, this would show up some glaring oversights, but in this case, it is an excellent pictorial reference of how to make this bike. I worked for a Yamaha dealer when these first came out. We weren't sure if the ere going to sell. They did, they sure did. I wish I could get a paper model of the bikes I own! Incredibly excellent! :)
