space station V
lyter1958
Esteemed Member
Jan 19, 2015
470
952
Bristol,Vt
here's my build of the 2010 spacestation v by Martin Sanger
this was a quick build.only took a week to do and yes i did leave off some items.
lyter1958
Esteemed Member
Jan 19, 2015
470
952
Bristol,Vt
and the rest of the build. i was't too sure of the stand but once it was all glued it's really sturdy
12,416
Very well done! Martin's version is the simplest I assume. Then comes the "simple" version by UHU02 and the detailed UHU02 version. :)
Reactions: lyter1958
9,567
Wheels are strong as any force applies goes around the structure and is absorbed well. If you have a crack in a piece of steel, many times it can be stopped by drilling a hole at the end of the crack. This gives time for welding without further damage. If a cast Iron cylinder head develops a crack, the same procedure can be done, instead of welding, a pin is pressed into hole with an interference fit, and that saves the cylinder head. The pins must be milled down to be flush with the head , of course. :)
9,567
I think they would make a nice pair, I don't think they made one of these!! ;)
lyter1958
Esteemed Member
Jan 19, 2015
470
952
Bristol,Vt
the stand is great, and the graphic is perfect backdrop. the only problem i really had was when each time i started to work on it, that damn BLUE DANUBE kept playing in my head...
ooohhhh crap, there it goes again....:hammerhead:
Reactions: Cybergrinder
