Pzkpfw. I Ausf. A, Orlik, 1:25
snake7
426
1,172
93
46
Israel
Thanks guys!
Next are steering brake levers
The rod itself I made from office fastener
Bugs:
detail 183 must be marked as count 2 and not one
snake7
426
1,172
93
46
Israel
Thanks
Built driver's seat.
The frame made from two sizes of solder wire
Glued parts 188a and 189a on 1.5mm cardboard and not 0.5mm, as suggested
This gave me more easy way to glue the skin on
And seat installed at it's place
Errors:
None
snake7
426
1,172
93
46
Israel
Front plate with all the stuff: instrument panel, radio set and couple of shelfs
For gauges glass imitation i used some thin plastic from old package
Assembled all together
Glued in place
Errors:
Gluing mark on detail 191 for detail 195 (radio set rack) must be full white and not frame. It confuses which side of rack to stick
snake7
426
1,172
93
46
Israel
It's time for hull's upper part
Starting from a frame
This one has a lot of angled sides, so designer gave support structure to glue all sides with right angles
On the left is the support structure, on the right is the hull part
Most of the parts must be cut with angled edges
In a matter of fact, it's really helped, and I connected all sides with ease
Also tried dry fit upper plate
Last part glued without support structure and frame of upper hull is ready
Errors:
there are some mistakes with left /right sides on parts K11, K13 and K15. So, you need to pay attention when assembling all together
snake7
426
1,172
93
46
Israel
Continue with visors mechanisms
Three of a kind
The front visor was a tricky one, but i doubt that i will play with those, though they are working and can be open
Errors:
Part 210 must be glued on 0.5 cardboard, but asterisk is missing.
Assembled part 226 does not fit correctly with part 219 - openings for visor position to wide
mijob
Tie designer
3,213
5,433
95
Netherlands
Holly smokes these visors are so looking good. You are doing a great job all so crisp and clear I'm blown away. :bowdown:
Reactions: snake7
snake7
426
1,172
93
46
Israel
Thanks friends
My patience for repeated small parts is not what it used to be.
So, in couple with holidays and pressure at work it took some time until i finished those machine gun magazines. Did it bit by bit here and there.
In addition made shelfs for those, rotation gear strip and two gas masks
Magazines
Shelfs
Gas masks and their mounting strips
Placed everything inside and filled up shelfs
Final touch was to close with upper plate. I thought to leave it open to see the inside, but noticed that even with it attached you can see almost everything inside the hull
Errors:
None
