Manson elevator
Discussion in 'Architecture Models' started by Steve Shaw, Oct 4, 2012.
  1. Steve Shaw
    Steve Shaw Member
    Manson Indiana is located northwest of the center of the state in Clinton county. The town is named after Mahlon Dickerson Manson a civil War general and Lieutenant Governor of Indiana. Manson was founded by three members of a Clark family in 1874, it had an early established church, and I have no idea if there were ever a post office, store or any other type of business supporting the community other than the elevator.
    Unfortunately I have no history on the elevator however from observation of what’s left of the building it appears to of been a painted wooden structure that has had several areas added and eventually the whole structure was covered with tin. There are also remnants of a brick cob burner. I would guess the age to be around 100 years, give or take 10 or 15.
    From the photos you can see Mother Nature slowly reclaiming the ground that this structure has occupied for many decades. The wind has removed some tin on the roof and sides letting in rain to start the decay process, some of the building has already begun to collapse. [​IMG]
    [​IMG]
    I have designed and built an N scale model of how I think the structure looked in its final days of use. Measurements are based on window and door openings and are not completely accurate.
    The model consist of 10 sheets of 67lbs letter size pages with 35 plus parts.
    [​IMG]
    All the parts cut out.
    [​IMG]
    I noticed that the silos didn’t have steel bar wrapping from top to bottom, just the upper and only a little over half. My though is that the bottom would have the most outward pressure.
    Note on tubes: tubes are easy it’s the cap or plug that’s hard to get the correct size. I made several and still didn’t get them perfect.
    [​IMG]
    Silos base and scale ramp.
    [​IMG]
    [​IMG]
    The major parts of the model are made from boxes of various shapes and sizes.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    I didn’t see anything left of stairs or walkway to access the two doors on the track side so my assumption is wood. I’m sure they didn’t jump up or down the 4 feet or so to get in or out.:eek:
    4 layers of 67lbs paper laminated and cut into strips were used to make stairs and walkway. Stair casings also cut from laminate and painted.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    All the boxes ready for assembly.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    The roofs hide a lot of the seams.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    The final touches are rigging, pipes and a winch beam.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Hope you enjoy this post, if you have any questions feel free to ask and if anyone has any history on this building please post it here.:thumb:
  2. Bhelliom
    Bhelliom Member
    I like this so much, I saved the entire page! N-scale? I can't make steps that look that good in any scale! I have an interest in the grain elevators, or whays left of them, on the Buffalo NY waterfront, and have considered building models of them. This will definitely be a good reference and inspiration for a way to build this sort of structure.
    Scott K.
  3. Zathros
    Zathros Guest
    That is really beautiful!! Are you making this model available? :)
  4. treadhead1952
    treadhead1952 Member
    Excellent work all the way around on your project! It would look right at home on a RR layout.
  5. PaperAir
    PaperAir Active Member
    wish I still had trains Excellent model.
  6. Steve Shaw
    Steve Shaw Member
    Thanks everyone for the kind words and vote of confidents.
    Sorry people but the model isn’t available at this time.
    Scott; I have seen some pictures of those old buildings and they are
    quite large, you may want to consider Z scale or add some internal structure.
    If you click on my name and the find more post tab you will find other post
    that could be of some help.
    Thanks again for all your support.
    SteveS.:thumb:
  7. Bhelliom
    Bhelliom Member
    Steve, if I do build one of the Buffalo structures, what I had in mind was to dock one of my lakers (in 1/700, 1/350, or 1/250th scales) next to it, so I'd be building smaller than Z in that case. There's a handful of smaller ones similar to yours closer to me that I'd make in N or HO. I'll still screw up the steps and fine details no matter what scale I choose, though :rolleyes:.
    I'll definitely look through your other posts for more inspiration, too.
    Scott K.
  8. Mr Marbles
    Mr Marbles New Member
    Really nice work. I've always found grain elevators to be some of the most interesting structures there are. Hopefully, I'll someday be able to scratch build something like this.
  9. Zathros
    Zathros Guest
    Hey, with 137 downloads, you could always cough this up as a little give pay back for all those who have given before you! (How's that for guilt tripping!) :eek: :p :twisted:
  10. Patron_zero
    Patron_zero Member
    A most unique yet still very brilliant model, grain elevators have a subtle understated charm all to their own design.
