First Time Assembled:
I worked yesterday evening into the early morning hours to assemble the working joints of both legs albeit with temporary diameter screws 6-32 until I found out if the design is viable.
And it WAS!
https://i.imgur.com/fXNC3DN.jpg
In the basic pose, legs straight, the inner side toes had just the right amount of clearance between the greaves at the most minimum width adjustment of the pelvic block.
I had made allowances for up to an inch per leg but it wasn't needed. If the model could actually walk, the inner toes would clear each other with each step.
https://i.imgur.com/NTpVqrQ.jpg
Next I adjusted the pose with one foot forward as if stepping out. The adjustment was made gingerly as all the friction axles aren't in place yet so the knee joints and hip sockets are rather stiff in appearance.
The dual axle hip sockets worked as planned, allowing the legs to be placed one behind the other as would be necessary if this contraption could walk as a true biped instead of a baby's rocking waddle which would look comical on a battlefield.
https://i.imgur.com/s8E7T0S.jpg
Again the limited range of motion due to the small temporary hardware limited the viability of the pose. With the right diameter hardware the poses will have a more fluid appearance.
Finally the spraddle legged Classic Titan Pose.
https://i.imgur.com/FbjPGwI.jpg
Again made viable by the dual axle hip joints is thankfully a reality......
https://i.imgur.com/F6p0kQx.jpg
In the Immortal words of Dr Strangelove; "Mien Fuhrer! I CAN WALK!"
MARTINI TIME!
