Baneblade build
Discussion in 'WarHammer40k' started by Floogen, Nov 15, 2018.
  1. Floogen
    Floogen New Member
    Hello all!
    I've just started building the Baneblade model that is Eli Patoroch,s design. I was really impressed with Silveroxide's build and wanted to try my hand at it. I'm a slow builder, so I will post progress pics as and when I can squeeze in some build time :) Comments, advice are most welcome!
  2. Floogen
    Floogen New Member
    OK here are the first few pictures of the chassis build. It's heavily laminated so as to withstand handling, and I use foamboard to help stiffen the structure.
    Next up is the engine compartment. Even though its more work, I decided to cut out the grills as I think they look better that just being printed on.
    I also modified the hinges, as I found the original hinges looked too flat, and I wanted it to look more realistic. I cut up strips of paper, and rolled them up, then squeezing both sides of the roll with my fingers to get that 'hump' shape of the grills.
    20181103_234221.jpg 20181109_204423.jpg 20181109_204913.jpg 20181109_220154.jpg 20181109_232917.jpg 20181109_232934.jpg 20181110_205847.jpg 20181110_215219.jpg 20181111_101946.jpg 20181111_101840.jpg
    zathros, Sudsy, micahrogers and 2 others like this.
  3. Floogen
    Floogen New Member
    For the other engine cover, it had a lot of grills over it (part 17 in the picture), so I decided to cut the whole rectangle out, and glue in individual grills, and used the same method of hinges above for the cover 20181112_103624.jpg 20181112_110736.jpg 20181112_134340.jpg 20181112_170837.jpg
    Sudsy, micahrogers, lyter1958 and 3 others like this.
  4. zathros
    zathros -----SENIOR---- Administrator Moderator
    Robust and strong looking model. You're off to a good start
    Floogen likes this.
  5. subnuke
    subnuke Moderator Intelligence Extraordinaire Moderator
    I like it. Looking good.
    Floogen likes this.
  6. Gandolf50
    Gandolf50 Researcher of obscure between war vehicles... Moderator
    Looking GOOD!
    Note on grills...I found that it is a bit better, and perhaps a bit easier to cut and burnish the grills on just about anything ( of course I can hardly hold anything so that may be why I prefer it!) I refer you to how I does it...
    MY GRILLS
    also a note on using a book punch... if you punch out multiple "rivets" they tend to get smashed together! Then when you apply them you sometimes get 2 smashed into one... It is when you paint that the top one falls off! Just a word of care... I saw some on the last build, I think!
    Yours is looking GREAT as it is, so keep on doing what you're doing and use my suggestions when the time comes!
    Floogen likes this.
  7. Floogen
    Floogen New Member
    Hi Gandalf,
    Great tips! I love the way your grills look so clean - can you please help elaborate more on how you did it?
    Not sure what's a book punch though...never used it...is it like a hole puncher?
    Thanks!
  8. Gandolf50
    Oh OH... I might have got 40k build mixed up! Anyway, the book punch is for punching holes..and used ( by Me and others) to make rivets! using the small ones the punch out from the holes leaves a small plug of cardstock, and that is what we use...
    upload_2018-11-17_8-21-16.png If you look at the grill here you can kinda see that there is ONE straight cut on the EDIT> FRONT edge. I then use an old pointed cuticle tool,( you could use anything that is flat on bottom/curved on top and comes to a point, you could file a finish nail and that would work, I just happen to have the cuticle tool) to insert along the front edge and holding my straight edge along the back side slowly push and burnish the card into shape, using the metal rule all the time, from R>L.
    Now I have to find that other 4ok build and look for the rivets I saw!;)
  9. Floogen
    Floogen New Member
    Hi all, and Happy New Year to all!!
    Sorry for the delay in updates - was busy with Thanskgiving, then Christmas followed by New Year :)
    Also, the next stage of the build, which was the wheels and tracks, was taking a loooong time to do.
    I had to do 32 roller wheels, 8 main wheels, and I made spokes for each of those wheels....you get the idea LOL
    Here are the pics of my progress so far...
    The engine exhaust was made from rolled up paper and wire.
  10. Floogen
    Floogen New Member
    Here are the wheels that sucked up so much of my time ...urrgh....
    They were made of card rolled up to the right diameter. The spokes were made of laminated card cut to the right length.
  11. Floogen
    Floogen New Member
    Aaannd I'm currently building the tracks now....another long process..
    Each track is made of 6 different sets/pieces as you can see below.
    The tracks were connected with toothpicks cut to the appropriate length.
  12. Floogen
    Floogen New Member
    To help break up the monotony of making tracks, I've also started working on the side bolters.
    Here's some preliminary pics of them
  13. zathros
    The tracks looks excellent. You patience is paying off. You model looks very square and true to form. Great!! ;)
    Cybergrinder and Floogen like this.
  14. Sudsy
    Sudsy New Member
    Monotony done right leads to incredible results!
    When you are gluing those parts, and you need a break, check out the artwork of a guy by the name of Virgil Finlay. He created the most incredible ink drawings by placing black dots. Tediously, by dipping his brush, and placing them one at a time... Inspiration to us all when we build the 100 of the same piece...
  15. JanMarciniak
    JanMarciniak New Member
    Sweet build :) Cant wait to see next step :)
    Cybergrinder likes this.
  16. Gandolf50
    Excellent! Glad to see someone ROLL up there parts instead of trying to create a tube by rolling a single swatch of cardstock... You didn't say it... but I would suggest a quick squirt of CV glue around the edges to seal them up tight! Nice job on the exhaust wire and rolled is the way to go!! Kudos!
    I love Virgil Finlay, and he actually used a pen nib which is way more difficult as those nibs will flick ink all over if your not careful, I used to do this same technique all the time but was lucky as I had technical pens to work with!
    Sudsy likes this.
  17. zathros
    I wonder what Virgil Finlay's nightmares were like. :)
