ARMORMAN's WARHAMMER 40K Models Thread
Discussion in 'WarHammer40k' started by ARMORMAN, Sep 2, 2011.
  1. ARMORMAN
    ARMORMAN FOUNDATION CORNERSTONE
    Glad you like them!
  2. ARMORMAN
  3. pastru79
    pastru79 New Member
  4. ARMORMAN
    I saw a new Warlord, but not the old Beetle Back version.[​IMG]
  5. Sanginus
    Sanginus Member
    great links,
    thanks for your good work and the many updates
  6. pastru79
    pastru79 New Member
    yes i know it s not the bettle back titan. i have some plans for the bettleback that someone send me but its not complete. if someone want to complete it ask me.
  7. ARMORMAN
    post some pics of the file as it looks now.
  8. ARMORMAN
  9. ARMORMAN
  10. gila8gila
    gila8gila New Member
    nice one, the Warlord look cool
  11. alienhunger
    alienhunger New Member
    You should rename the "Baneblade" label into "Baneblade body." Kinda almost freaked out when I saw it doesn't include the main cannon... Just suggesting...
  12. ARMORMAN
  13. jase9112
    jase9112 New Member
    Any chance of a wave serpant someday?
  14. ARMORMAN
  15. Slickaa
    Slickaa New Member
    Help with 02 Baal Predator build
    Can anyone point me to any instructions for this model?
  16. ARMORMAN
    Instructions were on the first page of the PDF.
  17. Harkonnen24
    Harkonnen24 Member
    Hmm, I wanted to try and build this model:
    New Russ:
    http://depositfiles.com/en/files/23yxx9z3j
    But no matter what I seem to do, I cannot get it to come out the same size as the Destroyer tank hunter I built. The track pods are a full 2cm shorter.
    Would look kind of weird having different size leman russ tanks beside each other lol, any ideas why?
    Edit: Yeah Armorman I've tried changing the paper size as well, just doesn't seem to have an effect, even when i scale it up to 100% and select a4 it still isn't the right size even though one of the trackpod pages goes off the paper. Don't have illustrator to change it around anyway.
    Edit 2: Yeah it is definitely the paper size, the 2011 leman russ is on 8.53"x11.94" meanwhile the older ones are 8.28"x11,69". Even taking a snapshot of the .pdf and putting it in MS paint won't work like the other ones.
  18. ARMORMAN
    check the paper size. I have found that the A4 page set up that they are using is right to the edge (and beyond, in some cases) of what is considered a normal printable area on most machines. My workaround is to import the files into Illustrator and re-lay out the parts (necessary as I am stuck with US Letter).
    OH, BTW, Imperial bunker v.3:
    http://depositfiles.com/files/8n11m8uxz
  19. stevew100
    stevew100 New Member
    I've had a problem with one of Patoroch's Mk1 Rhinos- it wasn't until I lined up the part-finished model with a plastic one that I realised it was about 10 percent too big! I found a PDF viewer that will scale the prints so I managed to fix it and start rebuilding. This aside, the models are excellent. I print on A4 so that's not the cause.
    Steve
  20. ARMORMAN
