brakie said:Well Some day.ops:
Nice locos. Lately I've been taking shots both with the flash on and with it off. Some shots look better one way while others look better the other. Uhhh, the use of the word "better" is a relative term in this case. I got a lot to learn about taking good pictures.brakie said:Bob,I forgot to mention I took that picture with the flash "off". I am beginning to like this camera far better then my old HP camera.
The best shots I got when I was able to wheel my layout on the driveway and shoot. That's what I used to do with all my product pictures when we had our business. Aside from blasting out one side of the house, I've now got to be satisfied with what comes through one window since the wheels are now in the garage, but the layout is inside the house.doctorwayne said:The first few photos that I took using my daughter's low-cost digital camera were done using the flash. None looked realistic, mainly due to glare from the flash. If the ambient lighting is reasonably good, it seems that the camera will compensate for the lighting and give a presentable picture. All of the shots that I've posted are done with no flash, and most of them under fluorescent lighting. Fluorescent lights do tend to "flatten" details, and I have started to occasionally used a handheld "trouble" light to provide a bit of added contrast. Your locos look good, although the second photo really makes the paint job look different. A good general rule of thumb is to keep the light source either behind you or between you and the subject. If the light is behind the subject, the camera usually "reads" the light, and the actual subject comes out too dark.
Wayne
Jules Winnfield said:More pictures Brakie! I think thy look PERFECT on that black bench.Any Bengals fan would be moved to tears! Thanks! All silliness aside... they are beautiful!
