- Apr 5, 2013
- 13,519
- 9,590
- 228
That is an absolutely brilliant solution!! One that will be copied in the future I'm sure. Well done!!
I agree with Z this is a Brilliant solution, and one I need to remember.That is an absolutely brilliant solution!! One that will be copied in the future I'm sure. Well done!!
1/2" medical gas tubing, made from anhydrous copper, once you break the seal on a 50' roll, you have 48 hours to use it, or scrap it, because the water vapor in the air starts to degrade it. 1/2" nominal OD, minimum wall thickness of .062, max wall thickness of .065. talk about easy to crush...Most of the design work I did required a tolerance of +or - of .005. There was a few things that the customer required +- of .0025
but my caliper only needed .001 scale, not .0001 or better.
That's strange, I only used 253 pages of 160 gm for that Optimus Prime build? (I did not print the instructions but viewed them on my pc).Which model is that? Sounds like a wonderful adventure!
In this case, I glue the back side with glue so that the wire does not fall inward, since I had to make 0.45 mm holes, due to the fact that it is very difficult to get into the 0.3 mm hole fitted to the diameter of the wire during weaving.Woe this is looking fantastic. Smart move to solder the wires. rinks:
