Build: Modelart F117 American Flag 1/72 scale
flpaperguy
86
306
40
66
Central Florida, USA
ModelArt offers 2 versions of their 1/72 scale F117: the Desert Storm version, which is mostly gray, and the American Flag version.
This 1/72 scale model has 4 1/2 pages of parts, 5 diagrams, and 1 page of assembly instructions (in English). I don't think this model will require any great feats of craftsmanship, but I expect putting together all the angled surfaces will be a challenge.
The instructions state there are some parts that need to be glued to 0.35 mm card. So, I laminated them to 1 layer of poster board, using Krylon Spray Adhesive. These parts are formers, stiffeners and landing gear tires.
Assembling this model requires a good scoring tool. There are a lot of score lines because the model is mostly straight lines. Where to score is indicated by short black lines on the outer border of the parts. I circled score indicator lines in red in the accompanying photo.
Chuffy70
846
1,711
Norwich UK
This kind of aircraft really suits card modelling, good start
The Typhoon had a similar patriotic motif over here for awhile whilst doing the display circuit
12,472
That looks cool! I'm looking forward to seeing how it turns out. :)
BTW, there is a version of the Canon eagle with stars and stripes. It looks awesome, too. :)
Reactions: flpaperguy
flpaperguy
86
306
40
66
All 3 landing gear bays are constructed and glued to the unprinted side of the fuselage's bottom. The front edges of parts 1 and 2, which are black in color, are folded over and glued to the unprinted side of the bottom. The front portion of the fold over lays flat and the back portion is raised a little by 3 glue tabs.
Next step is to glue the bottom of each wing to the bottom of the fuselage.
flpaperguy
86
306
40
66
Once the underside of the wings were dry, it was time to add several strengthening parts (which I previously laminated to post board) to the unprinted side of the fuselage's bottom. The positions for parts 9, 13, 16 and 17 (indicated by the green arrows the photo) were apparent after studying the diagrams for a couple minutes. However, the diagrams weren't detailed enough to show exactly where parts 14, 15 and 18 (indicated by the red arrows the photo) should be placed. It was obvious the larger parts (14 and 15) were wing supports, but I was puzzled where to put part 18.
After some experimentation, I realized these 3 parts were designed to fit together into subassembly.
Identifying the positioning of the subassembly was fairly obvious.
10,022
This model was printed by a laser printer at my local Office Depot store.
I would like to print all my models that way, but I found the printing has a tendency to crack and/or flake off when the parts are scored and/or bent.
I too have had very bad experiences with laser printing. I have heard that if you spray the parts sheets with a clear coat of lacquer to seal the print, it will not crack or flake. Unfortunately, I have not attempted this yet.
9,600
Stock to inkjet Pigment Ink printers. The Ink is archival (100 years +). Dye ink Inkjet printers run when wet, Pigment ink does not., and fade in the UV. rays, fading into a white model.
You will find most people use InkJet printers.
www.inkproducts.com is a great source of O.E.M. ink, and a great place to find which printer you may want to get. They buy ink from the O.E.M. suppliers, which means they get their Ink from the distributors of Dupont, who owns the patent for all ink. I use only Inkjet Pigment Ink products, they must be used at least once a week to keep the nozzles clean, it's in the nature that they work. That being said, if you buy a complete kit, it will come with a head cleaning solution kit, and more printer ink, and two sets of refillable cartridges that are also already filled.
Check out the website and go from there. If you aren't in the U.S., well, then this post is useless to you (as far as supply, not the technical aspect). You can call this company, they will pick up the phone. ;)
flpaperguy
86
306
40
66
Here's what the printed side of the bottom of the fuselage looks like. Note the wings have a faceted shape with several flat surfaces, which is created by scoring the lines printed on the top and bottom of the wings. The engines vents (parts 19 and 20 - the 2 black parts to the right of the fuselage) will be attached to the unprinted side of the fuselage's bottom.
Here is the correct orientation for the engine vents (as indicated by the yellow arrows in the photo). The glue tabs on the back of each vent are at the rear of the fuselage.
I covered the unprinted back portion of the fuselage with a piece of black cardstock to prevent white from showing through any gaps in the parts (indicated by the red arrow). Coloring that area with a marker would have been easier, but I didn't want to take the chance that the ink would bleed through to the colored side.
flpaperguy
86
306
40
66
The upper portion of the fuselage is constructed by gluing together parts 21-29 in numerical order (from front to back). Doing so was easier than I expected.
The next step is to mate the upper and lower halves of the fuselage together. There is a white line that runs from the front of the lower fuselage and across the inner edge of the wing. This is a guide line to show where the edge of the upper fuselage should be glued down.
9,600
Nice and straight, I've seen some of these come out kind of wonky. You've made sure every part was the way it should be, nice! :)
flpaperguy
86
306
40
66
Dry fitting the upper and lower halves of the fuselage is highly recommended before gluing them together. I started at the front. I positioned and glued the front edge of the upper about 17 cm from the tip of the lower. After the front was thoroughly dry, I glued down the first tab on the right. After that was dry, I did the first tab on the left. I worked my way down the sides, alternating to the left and right. There were 6 glue tabs on each side of the upper fuselage. The rear end didn't have glue tabs so I edge glued it together.
