There are some errors in the next steps comming up. I will show it in the next update.Cool! Thank you for posting it! It will be very helpful for my build
Thanks it is indeed a complicated model. Also its the first time for me to work with a pdo file. But yeah the designer could make things easier.That looked more complicated than it should have been...
Top work getting you head around that one
A little tip I have learned recently is that some black athletes tape along the Tab seams will stop light leaks, also black shoe laces on the adjoining seam will block light, or make a curtain to fall over the seam.Not a fan of the .pdo, but am amazed at what some people can do with them. I always cut the tabs off, and make a set to go on the inside, This places the edges on the same plan. It allows you to glue in the tabs first, then dri fit, and get the seems as tight as possible before you glue into place.
You did a GREAT JOB on this project!
Thank you both.Fantastic job!
