[R] Special type Rnh wagon for acid transport 1:25 scratch
draccus
22
43
www.facebook.com
Hello
Draccus is back with a new project.
A two-axle special wagon from 1938 used to transport acids in stoneware vessels. These wagons had a riveted frame with a specially adapted wooden floor for transporting 12 tanks of 1000 liters each. The wagon box was a specially constructed skeleton, made of steel sections on which a bridge was placed to facilitate access to tanks, and two raised wooden front walls. These vessels were only removed for maintenance. Filling was done from above by pouring each one separately while emptying by siphoning. An additional equipment of the wagon was the brake booth located on the back of the wagon. Due to the susceptibility of the ladle to mechanical damage, these wagons were gradually replaced by newer cisterns whose tanks were made of materials resistant to damage and corrosive substances.
Technical data
Total length 9.55 m
Width 2.51 m
Overall height 3.10 m
Curb weight 15 t
Capacity 15.75 t
Loading weight 15 t
Wheelbase 4.5 m
Loading capacity 120 hl
draccus
22
43
www.facebook.com
Soon, I should start making a stand that will also be part of the display case and then I will make a gallery with a camera with better parameters, because these were made with a phone and they are not very good. I do not have other photographic documentation from the construction site. The demanding model was not easy to build but somehow it worked out. Gentle wethering and that's how it looks
9,969
First off, let me say, WELCOME BACK! It is great seeing you back again!
Secondly, this is an AMAZING piece of art. As always, you have done a PHENOMENAL JOB on this project!!!
If I did not see that it was originally made of paper/cardstock, I would have thought that it was made from from something else. It looks very realistic!!!
9,564
Awesome build. What a scary vehicle!! You detailing is fantastic! :)
12,415
That looks great! I'm looking forward to seeing more. :)
One thing I noticed: You wrote "SAÜRE"; acid is "SÄURE" in German. ;)
Gandolf50
1,327
1,576
96
New Mexico USA
Welcome Back... Long Time No See...and Back with a BANG!! Great Build and Beautiful Details!!! but 1/25? looks way bigger than that... looking at your cutting mat and the parts! But I checked and sure enough 1/25 9.5M =15.3 Inches!!! BIG WAGON!! and nicely done!!!
IndyJets
60
157
40
41
How did you make all of the brake rigging on the underside? Brake cylinders, control valves, slack adjusters, and all that? Is that all paper? These components are all very similar to what is found on US freight cars even today. Do those parts actually move?
And was this a kit or a model you designed yourself?
Reactions: Awry_Chaos
draccus
22
43
www.facebook.com
This kit was designed and released by Me as a paper model. Some of the brake parts are laser cutted parts in cardboard. Only vats and couplings are printed in 3d resin.
