Thunder Fighter: MK-III ADVANCE (1:50 scale)
12,473
The whole scene would have made much more sense if they had used the TF which was a 2-seater from the start. However, if you assume the 2-seated Viper had already been in service at the time of BSG the scene also would not have made much sense since Apollo was referring to HIS Viper which clearly was a single seater. They should have rather gone with Adama's proposal to take a shuttle (which would also provide a means of transferring injured people and refugees from the surface) and have Apollo lead a Viper squad for protection.
How Carillon could explode at the end of the episode due to some local arson is another thing which is veeeeery far fetched. If you think about it the planet would have been gone long before the Colonials arrived. Yaknow, desert planet, low humidity, there must have been sand storms causing lighting and fires on occasion which would have doomed the planet's fate instantly. And of course the planet would have been much smaller than it seemed and consist only of mining caves which in essence would have turned it into a Swiss cheese. Too many weird things going on.... Ah well, let's avoid thinking about it. Did I mention how much I like the laser sounds during the space fights - Uh, oh.....! :bulgeeye: :noteeth: :drinksmile: :smoker:
micahrogers
3,792
4,664
Shannon GA
I wholeheartedly agree with you! The original Thunder Fighter is a very beautiful plane. It would have been interesting to have seen the TF as the Viper.\
We are of the same mindset, I like the modified Thunderfighter, but the original is my favorite. The X-29 and the Su-47 Berkut by Sukhoi are lovely planes, and both were very maneuverable, but then, as now, the limiting factor on maneuverability is the meat package inside, not the airframe.
10,030
Too right you are!
10,030
Love the cockpit, RF!
I've always liked your detailing work. I do it too, but not to the level you do!:)
Thank you very much for the kind words and encouragement. I have to say that you are one of the models builders who has always inspired me to add the detail work, and to try my hand at new techniques.
10,030
Ok, ladies and gentlemen, boys and girls, and all other assorted creatures (both human and not); it is time for another update.
I have moved on to the body's internal formers and supports. Now, with this, I decided to take a page from the notebook of a friend (and fellow member) @silveroxide (who when he built his TF, he laminated the formers to add additional strength). Now, I know that I really do not need the added strength in this model (mostly because of its size and scale). However, I figured, since I am building it, that I would give it a go and see just how it will work out. All of the formers were laminated to (roughly) 1mm thick (I used the cardboard from old cereal boxes).
The formers are in place.
The rear engine skins were attached.
Here are the wings. Now, unlike the original (i.e. the main one/two seat, HBB and quad) version (where the wings are just placed on the sides to cover the seam of the rear section of the engines), these forward swept wings (FSW) have an internal former/mounting piece. I laminated standard cardstock on both sides so that the mounting piece is more "centered". I have also recessed the vents and the three ovals that are on either side of the back end of the wings.
The internal former/mounting pieces are in the wings.
The wings are in place.
*NOTE* Please pay special attention to the instructions when putting the wings in place.
These are the internal formers for the lower rear section. Normally, there are only three pieces. I have split each in half and laminated them to (roughly) 1mm. This will give added support to the lower rear section.
The formers are in place. You should attach the front end of the rear bottom panel (part 247) before placing the formers. Otherwise, the panel tabs will not sit right.
If you look closely, I have placed two of the longer formers just on either side of the hole for the cockpit tub.
The rear bottom panel is secured.
Both the top body half and the bottom body half are attached.
Please say tune to your local Earth Directorate broadcasting channels for more updates.
12,473
It always amuses me to look at the two halves lying next to each other on the cutting mat. It looks like you were assembling two models, but then shortly thereafter the halves are combined and form (only) ONE fuselage ;)
bigpetr
Designer/Master Modeler
Jan 27, 2016
925
1,469
Czech Republic
Great progress, realy like this design. And black version you did receantly too. :)
Added strength never hurts. Especialy if builder plans to add plenty of details, like you always dothumbsup. I rather overdoo the internal structures than find out later in the build it is insuficient (lesson I learnt the hard way)
Awry_Chaos
OKB-4155
Dec 22, 2020
1,228
1,572
95
49
Spokane, WA
The neat thing is these can be customized and detailed in pretty much any way you want.
Awry_Chaos
OKB-4155
Dec 22, 2020
1,228
1,572
95
49
Spokane, WA
If Rhaven wanted to he could start his own Thunder Fighter production line. He probably already holds the world record for the number of Thunder Fighters built by one person!
10,030
It is funny that you mention how many TFs I have built over time. Here is a photo of the collection that I had when I was in Eastern Europe. With the exception of the back center (which is a scratch build), all of these were test builds.
Awry_Chaos
OKB-4155
Dec 22, 2020
1,228
1,572
95
49
Spokane, WA
Awesome! I love the back center one. What's the story being that one? Is that the one you built for your Mom?
Reactions: Rhaven Blaack
10,030
Actually, the one that is front and second to the right was the one that I made for my mum. The back center one was a scratch build that I did to see what it would look like if I put forward swept wings on it. after I had built it, @Revell-Fan suggested that we make an "add-on" kit of it for the @Martin Saenger kit (hence the MK-III (FSW) version).
Reactions: micahrogers
Awry_Chaos
OKB-4155
Dec 22, 2020
1,228
1,572
95
49
Spokane, WA
I have the feeling your Mom is immensely proud of you!
The MK-III is a great design especially the scratch built one.
10,030
Thank you! I make the one for my mum as a memorial for her. With that being said, if she were still alive when I had made it, I know that she would have loved it. She greatly enjoyed both BSG and Buck Rogers (hence the TF in BSG livery).
