Maintenance robots 'Dewey', 'Huey' and 'Louie' designed by UHU02
9,987
Good morning Ladies and gentlemen,
It is time for another update to this thread.
Moving to the face plate and the mount for the actuator arm.
Here are the parts.
For the face plate, I raised the center gray part, the wires, and the connectors. For the mounting post for the arm, I raised the collar and cut the holes out. As for the "stabilizer" arm. I made the thinner part of the arm a bit thicker and made the top connector piece a bit thicker.
The face plate is in place, the stabilizer arm is attached and the mounting post for the arm is in place.
9,987
Here is the first part of the actuator arm.
These are the hydraulic/pneumatic parts.
The hydraulic/pneumatic parts are assembled.
Here are the parts for one of the stabilizing braces and hydraulic/pneumatic piston.
The stabilizing braces and hydraulic/pneumatic piston.
Here is the second half of the arm.
The first part of the second half are attached.
Here is another hydraulic/pneumatic piston.
The hydraulic/pneumatic piston is attached.
This is the front cover of the arm.
This is the front cover of the arm. As you see, I layered some of the panels of the cover.
The cover is attached.
9,987
Here are the parts for the hand (yes with a hand of cards as well. Yes, it is a royal Flush of spades).
This is the connector (wrist), hand itself, and the "pincers".
Here is the royal Flush of spades (ROBOTS CHEAT).
Yes, each card is individually cut out and layered on the next one.
The whole arm is now assembled and attached to the arm mounting post.
The robot is now finished.
Here three of the robots together.
So, now on to a new project!!!
9,591
They look just like the bots in the movie. Excellent job!! ;)
Reactions: Rhaven Blaack
