Star Wars A-wing / Shunichi Makino + heavy mods/ 1:48
bigpetr
Designer/Master Modeler
Jan 27, 2016
922
1,461
Czech Republic
Thank you guys. So far I am happy with it.
Only thing that bothers me (in general) is color stability of printed models. I put lots of time and effort to make my builds realy detailed so I want it to looks good for a long time. Paper yelowing and printed color unstability in time bothers me. I thought about painting my models, but painting is another beast I do not know I want to get into, well at least right now. I can not decide :).
9,572
What an excelent improvement!! :)
9,973
One of the things that you may want to look at is, once the model is finished, sealing it with a clear coat spray. It should help with protecting the model from fading and yellowing.
bigpetr
Jan 27, 2016
922
1,461
Czech Republic
I am using clear coat spray. It surely helps, but it only slow down the proces in my experience. But I found solution to this problem. I made opaque display case:):bulgeeye::lolsign:
Reactions: Rhaven Blaack
Gandolf50
1,327
1,576
96
New Mexico USA
and to add...spray the pages just after printing... acrylic matte varnish... soak each side with just enough that the page starts to look translucent, stops runs in coloring edges, stops the glue from penetrating into the paper, causing warpage...and protects the surface...
and then get a decent airbrush and paint it!! ( just kidding ...sort of ) ;) ;)
bigpetr
Jan 27, 2016
922
1,461
Czech Republic
I enclosed the frame. It gave me a hard time. After gluing it made dents on the side of the hull. I thougth I am done and seriouse redesign would be needed. After I calmed down I cut the hole to the back where engines will be atached and stuff paper tissue inside to smooth the dents and it saved the day. It worked good and leftower imperfections will be covered by smaller detail. I can say I was really happy I do not have to redesign it.
9,572
Incredible detail and workmanship! :)
9,572
Really, this is past words. Man that looks great!! :)
bigpetr
Jan 27, 2016
922
1,461
Czech Republic
Thank you very much. I am happy that everything fits good so far and no template changes needed. Now I need to go back to the computer and texture parts from the back and prepare the parts for the canopy plug and first batch of the greeblies.
Reactions: zathros
