More pics - cargo bay
Cargo bay - I was just about to put the assembly above onto the cargo bay when two things were realized
1. The wings should be installed and
2. There's a big blank white spot on the sides.
Realizing this, work proceeded on the side supports which originally (I thought) were just for the landing support pads.
Also after looking at the Serenity from the series there's a series of support under the wings.
Side cargo bay supports. Note the two supports on either side are glued first. Then you work inwards. The top of the template is folded backwards to give a black covering to the support.
Side supports ready to be installed. Note that tabs were added to the engine / wing assemblies to help reinforce and keep the wings onto the cargo bay. There is no special reason for the tabs beings colored. They were just cast off pieces that became not so cast off. Make sure that you make a pair of incisions within the wing area on the cargo bay.
As a test fitting was being done I realized the following.... Houston we have a SERIOUS problem!!
:frak:
:robot3::robot3::robot3::robot3: :exterminate:
Yes those wonderful side supports that I thought needed to be added are now causing all sorts of havoc!
However, never fear we look at these little mishaps in life as challenges that need (no they are begging) to be overcome!
This is what was done.
Remove the center support as shown below. Next cut the edges between the other two supports to form a flap.
Glue the area under the flap then fold the flap down.
That's it.
Note the incisions made in the wing area on the cargo bay.
Before adding the wings I was debating weather or not to add the engine cowls. After doing more research the engine cowls were finally added. The hard part about this was trying to figure out where to start the cowl. As you can see below you start at the edge where the wings connects to the engine then overlap the cowl about the engine until it contacts near some "yellow squares".
Now you slide the tabs into the incisions on the cargo bay. Make sure to add glue onto the tabs and to the wings adjacent to the cargo bay. Note that wings slide in pretty well now. Note the area with the "yellow squares".
After the wing is inserted for additional strength overglue as shown below to add additional strength to the wing.
That's it for now.
Sky Seeker
:tank:
