Space Wulf Dreadnaught
silveroxide
2,036
525
Fayetteville NC
After a long sabbatical, I am back with another build thread. The comments are in the photos so enjoy the sequence trip. I did use a Games workshop model for reference and did make some adjustment to Eli's model. It is the approximate same size as the Games Workshop model, and it is sturdy enough to handle a table top game. The design is by Eli Patoroch and is over at amormans thread.001.jpg
Here are a few shots of the finished model and a games workshop model which I used as reference
9,959
It is good to see you building again!
This is FANTASTIC! As always, you are doing a SPECTACULAR JOB!
My son is into WH40K. I may have to build one for him if he sees this. :cool:
9,559
The Master is back, and back to building. So nice to hear from you!! :)
Reactions: Revell-Fan
silveroxide
2,036
525
Fayetteville NC
More updates on the Dreadnaught. As you can see by now, my verdsion is slightly different from Eli's. He gave me a great base to start with. That hip joint is the weakest part of the dreadnaught, so to make it strong, I heavily laminated the joint and added drilled holes to insert rods/pins. The rods/pins will give the joint strength to handle the table top gaming.
9,559
Your Grandchildren must be dying to get their hands on these!! :)
silveroxide
2,036
525
Fayetteville NC
Actually, my grand kids do not have that artistic urge like their grandpa. They are mostly in favor of anything that has to do with ball, baseball, football, basketball, soccer, etc etc.
And now to place the new updates on screen for your pleasure.
The rolled strip will go on a dremel and get rounded off to make that ball joint.
12,389
Absolutely fantastic and stunning work! :)
Silver, you have not "unlearned" anything! This is top-notch quality. Carry on, please! :)
silveroxide
2,036
525
Fayetteville NC
Thanks for your kind words. As usual, my build techniques are a bit different but the results is what matters.
So here is the next set in the build technique.
The ends of the Hydraulics are small cut pieces of paper rods from and ear swab.
silveroxide
2,036
525
Fayetteville NC
Thanks for all of the likes. I am pleased that you have looked in and enjoyed my build thread.
And so the build thread continues. The foot pad template has added tabs which are to be folded underneath the pad template. A wrapped cylinder is made to fit the ball joint. This will allow for better posing . The plans have this section cut at an angle and it would have to be exact to place the legs on the foot pad. With the ball joint, you can place the legs into different poses.
spaceagent-9
Right Hand Man and Confidant
3,119
3,483
143
62
pheonix
that's really cool!! for some reason I think of silent running bots, heuy duey and louie
silveroxide
2,036
525
Fayetteville NC
This is really looking good!!!
Thanks for looking in and for your comments. As for the silent running bots, the boxy shape is reminiscent of the bots.
The pads are constructed a bit differently from the plans. The ball joint is better suited for posing the dreadnaught. Not only that, but is more sturdy for constant handling. The hip and leg section is the weakest part of the model. Because of this, I made sure that it is very strong.
